Computer Build ignorance
Hey!
I'm going to upgrade my pc (cpu, mobo, RAM, and maybe a case), and I'm really worried about my graphics card.
I currently own a gtx 580 matrix, and it is HUGE. Since i always see micro mobo's being advertised on the cheaper builds, i'm leaning toward those. but my question is will the gpu slot be too close to the edge of the case? (my case will barely hold it now, and i have a regular mobo,
If i need to upgrade my case, what would you recommend that's pretty cheap?
Thanks in advance!
What case are you getting make shure that It has enough clearance for your GPU as you intend on keeping it there is really no other question to it
first off, measure the space in your case, then pick out a graphics card. Look at the size of the graphics card, does it fit? awesome. Does it not fit? get a different cased or a different gfx card.
PCI-E slots on micro-ATX boards are always the first or second slot and two or three after it so the 580 will have enough slot room on any micro-ATX mother board and up and micro-ATX case and up, as far as the card being too long, you need to measure the card and read reviews on cases
