Computer Build.. help?
Here is a list of everything I want in my budget gaming PC, please let me know if this is a good build! I got most of it from Logan's $500 PC build video, but changed some of it up according to how I would like it.
List:
BIOSTAR B75MU3+ LGA 1155 Intel B75 HDMI SATA 6Gb/s USB 3.0 Micro ATX Intel Motherboard
Which can be found here: ($69.99)
http://www.newegg.com/Product/Product.aspx?Item=N82E16813138357
G.SKILL Sniper Series 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1600
Which can be found here: ($59.99)
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231460
LEPA B550-SA 550W 80+ bronze
Which can be found here:  ($59.99 – sale or $69.99)
http://www.newegg.com/Product/Product.aspx?Item=N82E16817194102&Tpk=LEPA%20B550-SA%20550W%2080%2b%20bronze
NZXT GAMMA Classic Series GAMA-001BK
Which can be found here: ($39.99 – sale or $49.99)
http://www.newegg.com/Product/Product.aspx?Item=N82E16811146061
EVGA GeForce GTS 450 Superclocked 1024 MB GDDR5 PCI Express 2.0 2DVI/Mini-HDMI SLI Ready Graphics Card, 01G-P3-1452-TR
Which can be found here: ($131.28)
http://www.amazon.com/EVGA-Superclocked-Mini-HDMI-Graphics-01G-P3-1452-TR/dp/B0041RRNDK/ref=sr_1_1?s=electronics&ie=UTF8&qid=1342559137&sr=1-1&keywords=Geforce+gts450
Intel Core i5-2500K Sandy Bridge 3.3GHz (3.7GHz Turbo Boost) LGA 1155 95W Quad-Core Desktop Processor Intel HD Graphics 3000 BX80623I52500K
Which can be found here: ($220)
http://www.newegg.com/Product/Product.aspx?Item=N82E16819115072&Tpk=i5%202500k
P.S. I want to be able to play Arma 2 on high settings!
Drop the GTS 450 and go with the GTX 560SE as that's more cheaper and better. http://www.amazon.com/EVGA-GeForce-GTX560-Graphics-01G-P3-1464-KR/dp/B007TMXFE0/ref=pd_cp_e_2
you can also get that card on newegg
get this PSU instead
http://www.newegg.com/Product/Product.aspx?Item=N82E16817182200
has way better wattage and amps on the 12 rail
get this ram instead
http://www.newegg.com/Product/Product.aspx?Item=N82E16820313203
is the ram I would tell you if your weren't getting a b75 chipset, which with sandy chips only run memory at 1333, you can't make it go faster or change settings, you'd be better off going with a z68, z75 or z77 chipset for 15 bucks more
http://www.newegg.com/Product/Product.aspx?Item=N82E16813157304
and you have a 2500K, overclock that bad boy to 5GHz on this baby
http://www.newegg.com/Product/Product.aspx?Item=N82E16835103089
or 4-4.5 on this if you're pinching pennies
http://www.newegg.com/Product/Product.aspx?Item=N82E16835103065
but the V6GT will do so much better
i totally agree with you, the gts 450 is already 3 generations old while the gtx560 se is from the previous generation, it will give you a lot more performance :)
