So i have $600 for amazon and $500 of my own money currently have a pc i built back in 2012 with hd7870 amd phenom II 4 965 and corsair vengeance 4gbx2. Im not an expert at this stuff but know how to build a computer I want to be able to game on it with best settings possible would be awesome to get 4k but I dont think thats possible with this budget just looking for any builds I could do I definitely need new motherboard because certain ports such as ethernet port have gone on it but if i can salvage some stuff and get to 4k in this budget that would be sweet thanks
Well you could start here, did you also need a monitor and stuff for that budget?
PCPartPicker part list / Price breakdown by merchant
Type|Item|Price
CPU | Intel Core i7-6700 3.4GHz Quad-Core Processor | $339.99 @ B&H
CPU Cooler | Cooler Master Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler | $28.59 @ Amazon
Motherboard | Asus H170M-PLUS Micro ATX LGA1151 Motherboard | $103.75 @ OutletPC
Memory | Crucial 8GB (1 x 8GB) DDR4-2133 Memory | $43.99 @ SuperBiiz
Storage | Hitachi Ultrastar 1TB 3.5" 7200RPM Internal Hard Drive | $54.00 @ Amazon
Video Card | Gigabyte Radeon R9 390 8GB SOC Video Card | $319.99 @ SuperBiiz
Case | Deepcool TESSERACT BF ATX Mid Tower Case | $33.99 @ Newegg
Power Supply | Rosewill HIVE 650W 80+ Bronze Certified Semi-Modular ATX Power Supply | $70.72 @ Amazon
| Prices include shipping, taxes, rebates, and discounts |
| Total | $995.02
| Generated by PCPartPicker 2015-11-12 00:54 EST-0500 |
what sort of usage? do you need a screen/s? peripherals? i assume the states?
i have a 1920 x 1080 ips 22" monitor i assume theres no 4k monitors or better than mine i can fit into my budget.
Well I mean ya could, but a decent IPS 4k monitor is about 550, so you'd end up with a PC like this
Type|Item|Price
CPU | AMD Athlon X4 860K 3.7GHz Quad-Core Processor | $68.99 @ NCIX US
Motherboard | Gigabyte GA-F2A68HM-DS2H Micro ATX FM2+ Motherboard | $46.99 @ SuperBiiz
Memory | Patriot Signature 8GB (2 x 4GB) DDR3-1600 Memory | $32.99 @ NCIX US
Storage | Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive | $49.99 @ Newegg
Video Card | Gigabyte Radeon R9 390 8GB Video Card | $299.99 @ SuperBiiz
Case | Fractal Design Core 1000 USB 3.0 MicroATX Mid Tower Case | $33.99 @ SuperBiiz
Power Supply | Rosewill 600W 80+ Bronze Certified Semi-Modular ATX Power Supply | $59.99 @ Newegg
| Total | $592.93
| Generated by PCPartPicker 2015-11-12 01:41 EST-0500 |
or
Type|Item|Price
CPU | Intel Core i5-4460 3.2GHz Quad-Core Processor | $169.09 @ Amazon
Motherboard | MSI H81M-P33 Micro ATX LGA1150 Motherboard | $42.89 @ OutletPC
Video Card | MSI Radeon R9 380 4GB Video Card | $194.99 @ Newegg
| Total | $583.93
Which if you wanted to go 4k, the 860K+390 is not a bad option to push for 4k at lower settings
With this, which is 4k IPS and free-sync for $500, only 27"
https://pcpartpicker.com/part/lg-monitor-27mu67
Personally if I had a thousand bucks I'd do it, but I don't really care too much about having the highest performing PC, either of those builds is going to be fine for gaming, and then you have the screen real estate of 4k, though a 40" 4k monitor is a good deal more usable
i will probably just go with the first build i dont feel i will utilize 4k as much not really any games seem to run at 4k yet
mostly with 4k you just never have to worry about running out of space on your display to put stuff
do you think an fx8350 would bottleneck a 390x if i were to go that route and if not what atx motherboard would be good to go with it
....... btw thanks for all your help so far so many decisions
You'd want a 390, not a 390x, it's not worth the extra 100 bucks or so, but if you overclock the 8350 it'll still pull over 60fps in the majority of games, you'll only run into a bottleneck with something like total war or CoH 2, which not too many people play really
ok then is there any other suggestion for the cpu because im looking to buy the processor through amazon or new egg jus because its easier for me and the one suggested earlier seems to be sold out on both sites
not really, if you're just gaming all you really need is an i5 4460, or 860k if you want to save money
ok sweet thanks for your all your help today
