Computer build: compatibility confusion!
will this stuff work together and what do you to find that out?
AMD A10 5800K Black Edition
AsRock FM2A75M-ITX
Corsair Builder Series CX 430 Watt ATX/EPS
Crucial 8GB (2 x 4GB) DDR3 PC3-14900 240 Pin Memory
Ok, first, just check the socket type (Aka FM2, AM3, AM3+) and the chip type (A75, 1155, etc..)
Then check the Pin count on the RAM and check that with the Mother Board.
PSU's generally work with everything seen as it is more of a universal input for things.
I have a slight issue with amazon's naming of the Mother Board, it has labelled it as both an AMD Socket (FM2A75), and Intel socket (ITX)
But yes, that will all work together. if you want more detail on the parts, check on the manufacutre's site.
