Complicated prob
okay, i installed ubuntu, I want to uninstall it. but it hid the drive from windows, so I cant format the drive its installed on. and when I boot I get these screens, and I want to get rid of all of them?
I know complicated.
First one
[IMG]http://i278.photobucket.com/albums/kk87/nate22181/P1010075.jpg[/IMG]
second one
[IMG]http://i278.photobucket.com/albums/kk87/nate22181/P1010078.jpg[/IMG]
I want to get rid of these boot selectors althogether so my comp will just boot on vista, without going to these screens, this only was put there when I installed linux.
The open suse...and ubuntu and windows setup dont work on the second image, so how can i just deledte everything?
Run Ubuntu live CD again, and click Install. Should be option to delete partitions, etc.
Boot back into Vista, format newly erased partitions for Vista.
Option 2 in case of trouble: Use Dban to nuke whole drive, reinstall Vista.
well, i have an extreme warning for you. i had this same problem. i didnt want ubuntu anymore in dual boot, but the screen was there. heres the problem, if you try to delete the partition the boot loader is on, you will never be able to boot into windows and you will have to re-install. there probably is a fix, and i havn't looked very hard for one. but if i were you, i would just live with it. its not so bad
THANKS ALOT GEORGE AND SKUMP>>> READ THE "SHIT!!!" post..... no im just joking..
its okay, im not mad at you, im mad at linux.
lol i posted like a min. before you posted that
"i had this same problem. i didnt want ubuntu anymore in dual boot, but the screen was there. heres the problem, if you try to delete the partition the boot loader is on, you will never be able to boot into windows and you will have to re-install"
i in my drunken stupidity did that with open suse and ya... its gay. i just used bartpe to get all my music and stuff off then reinstalled.
