nav27v
February 26, 2013, 12:11am
#1
I have finally completed my computer build (my first by the way) and I am pleased with the results.
You can find the specs here: http://ca.pcpartpicker.com/p/BwkK
It runs Planetside 2, Battlefield 3 (on Ultra), Minecraft and just about everything I have thrown at it at a solid 60fps. And it is $700.
looks nice, i have the same case, just not as pretty on the inside
Slimm
February 26, 2013, 1:09am
#3
nice job, man! Shame that you could of had case with good cable routing holes, but all well!
btw, How's that asus mobo doing for you? all good? I might wanna use this board for my friend with an 8350
nav27v
February 26, 2013, 1:34am
#4
The motherbaord seems good. It runs the 8350 without any BIOS update.
Only issue is it didn't recoginize my exact ram as 1600mhz. But all I did was set it manuallto that and voila it works fine.
How's OCing on that motherboard? I have one shipping this thursday for my new 8320 build.
nav27v
February 26, 2013, 2:10am
#6
I haven't tried overclocking yet, but form what I see a bit of an overclock should be easy to get. But I wouldn't push it too far on this one, maybe 400Mhz max becasue the power system may not be able to handle that much.
