Complete Setup for 1000 €
Hey people,
I requested a system config a couple month ago but never had the time to buy it because uni kept me busy.
Since new hardware is out, I'd like to ask for help again.
Here are my requirements:
1) Gaming rig (1080, should max out many games) , MAYBE a little bit of film editing. But nothing too fancy.
2) OC: No, don't need it.
3) cable management: Yes, I want a clean look inside my case.
4) Case: No Black. I like white and grey, partially black is alright.
5) Power efficient. Electricity might be cheap in America, but it's expensive here in Germany.
6) Mouse and Keyboard required.
That's about it. Any help is appreciated.
I created a build on tweakers.net for you, Note that the prices are Dutch, but most parts should be availeble in Germany aswell. Since the taxes are lower in Germany you might be cheaper on some parts.  I did not add keyboard and mouse, cause that is something very personal.
http://tweakers.net/gallery/526243#tab:wenslijst
I think a build like this should fit all your needs. maybe you have to add a few € for some decent keyboard and mouse. For gaming this setup, will be fine for most games at 1080P. i was trying to put a R9-290 in there, but then i went over budget, but if you could afford a R9-290 instead of a R9-280X it could be definitely something to concider. However a 280X should be fine for maxing out most games at 1080p.
You could also concider going the AMD route offcourse. FX8350 with Asus 990FX Pro R2.0 R2.0, this will save you some cash, but thats up to you. FX8 core will definitely help some what in rendering. over the i5, so thats something to concider.
I was trying to put it in partpicker, But partpicker for Germany kinda sucks.
Let me know what you think.
Grtz Angel ☺
