Compatible Parts? First time building a pc
Hello. This is my first time building a pc. All I want to know is if all the parts are compatible and if it's good for gaming. I don't want to Overclock and I don't want to play every game at ultra settings, I'm okay with playing at medium settings.
CPU: AMD FD6300WMHKBOX FX-6300 6-Core Processor Black Edition
Motherboard: MSI 970 GAMING DDR3 2133 ATX AMD Motherboard
CPU Fan: Cooler Master Hyper 212 EVO - CPU Cooler with 120mm PWM Fan (RR-212E-20PK-R2)
Ram: Kingston HyperX FURY 8GB Kit (2x4GB) 1600MHz DDR3 CL10 DIMM - Black (HX316C10FBK2/8)
Hard drive: WD Blue 1TB Desktop 3.5 Inch SATA 6Gb/s 7200rpm Internal Hard Drive
Graphics Card: EVGA GeForce GTX 750Ti SC 2GB GDDR5 Graphics Card
Case: Corsair Carbide Series SPEC-01 Mid Tower Gaming Case CC-9011050-WW
Power Supply: EVGA 600 B1 80+ BRONZE, 600W 3 Year Warranty Power Supply 100-B1-0600-KR
Yes, everything in that build works. I think you should get an SSD to put your OS and some of your favorite applications on just because SSDs have gone down in price a lot lately and you can pick up a quality one for not that much money. Other than that it looks like a solid entry level build.
Okay. I'll try to get an SSD. Thank you :D
My first build had a 6350 in it as well. They overclock like a beast and a hyper 212 Evo should be more than sufficient enough to get it up to 4.4 or better. Welcome to the glorious inner circle of the glorious pc gaming master race! gabeN be praised!
I'd change a few bits about that build to put more into the GPU and try to get a 380 and add an SSD if I could, but those parts will work together.
