Hello.
Is this: http://www.asrock.com/mb/AMD/980DE3U3S3/?cat=Memory
compatible with
this: http://www.amazon.com/G-Skill-PC3-12800-RipjawsX-9-9-9-24-F3-12800CL9D-8GBXL/dp/B004I763AW
Thanks for answers!
Hello.
compatible with
Thanks for answers!
Yes, you would be hard pressed to find a motherboard that would be incompatible with a 1600MHz kit. Compatibility problems usually come from higher speed kits. 1600MHz is universally compatible with any ddr3 motherboard designed in the last 3 or 4 years.
Good to hear. ty for your answer
