Alright, so I just wanted to know if the ASRock Z77 Extreme 4 LGA 1155 would be able to support two GTX 680 DIRECTCU II TOP's in SLI. If not, which motherboards have the capability of this? Thanks.
You can do this research on your own. Check if the board has SLI, and if the PCIE slots have 2 inbetween the slot your using, and the next slot you will be using. Yes that board does work
