i'm building a computer and would like to make sure all of these parts are compatible. If you could help by telling me its good or any warnings you have on these products
Looks compatible to me.....
these look perfectly fine and all compatible. Decent setup, I'd definitely go for it :)
its more of a price-to-performance build because i want something lower price but that will last for awhile
Stay away from Cooler Master GX psu's
http://www.hardwaresecrets.com/article/917
http://www.hardocp.com/article/2010/11/22/cooler_master_gx_650w_power_supply_review/#.Ui-iuca1FCC
Allso you dont need 750w's even if you had x2 hd7850's
Pick up a XFX 550w a seasonic 500w a lepa g psu much better psu's THAT WHONT SET YOUR COMPUTER ON FIRE!
And the GIGABYTE GA-990FXA-UD3 is not the best a Asus M5A99FX PRO R2.0 is ten times better for the same money.
damn, what happened there
All looks good, although as suggested id avoid that PSU and go for something from Corsair/XFX or Seasonic, the Gigabyte board is perfectly fine, i used to use ASUS but had terrible issues when it came to customer support (ASUS products are good but if they go wrong its a world of hurt).
Id also suggest getting an aftermarket CPU heatsink for the 8350, stock heatsinks are ok but usually its better to spend an extra 20 and get a better one.
2 other viable options for you, have a shop around and see what suits your fancy/budget. (ive linked the 750watt corsair one as its the same wattage as the CM one, i do think 750 is a little high, perhaps think about dropping to the 600 area would be better).
what do you think about these
i would say the evga 500w one would be good, you dont need 750 watts, also you might want to rebalance your system, possibly a 7950 and an fx-6300 apposed to that lower end card that will give you less performance than if you had a 6300, which is going to perform about as well as the 8350 in typical gaming situations. and the HD 7950 will give you a huge boost over the HD 7850.
Why would you want 750w? Thats so overkill and EVGA do not make good power Supplies. Get Antec, XFX Or seasonic.
You dont need 16GB of RAM thats a total waste of money, You should get 8Gb's and get a better GPU. Thats the thing that matters in a gaming build. Get a 7870 or 760.
Also if you get a Seagate Barracuda there's a 40% chance of it being dead on arrival. Grab a caviar blue instead.
