According to pcpartpicker the ryzen 7 2700X is incompatible with the B450 Tomahawk Max motherboard. I checked on msi’s list of supported cpu’s, and its missing. What makes me find this specially odd is that is supports the 2700 and 2700X pro versions and the 2700 (non pro).
I was going to use the relevant msi link, but the forum doesn´t allow (this is my first post).
I mean… the only reason I would see is that pcpartpicker takes its info from msi´s website and msi made a mistake. But if that is so, then I don´t understand the lack of builds using the two.
What else could this be? I was really looking forward to purchasing this combination of items.
Also where can I find the appropriate ubuntu 16.04 drivers for this board?
The only reason i could really think off,
is that the 2700X in particular is a pretty powerhungry chip,
at least when you really want to push it in terms of all core overclocking.
The vrm implementation of that said board is kinda okayish but not great.
So i could kinda see why the cpu wouldn´t be on the recommendation list.
But it should still work basically.
It’s a B450 board for the Ryzen+ cpu’s on which the 2700X,
is one of them.
If you have the money for a decent X470 board like the Asrock X470 Taichi for example.
Then i would definitelly recommend that for a 2700X.
There are not really any linux drivers available for any consumer grade motherboard.
Drivers support for linux is build into the kernel for the most part.
so in regards to all the basic stuff should work out of the box.
But don´t really expect any support in regards to RGB control,
or fan control or anything for the board in linux.
Because it’s simply not there.
Also Ubuntu 16.04 is already EOL and unsupported.
So in regards to that for Ryzen i would recommend to use Ubuntu 19.10 for now.
And upgrade to 20.04 LTS when released next year.
Actually the 3900X and the 3950X are just as power hungry as the 2700X.
The VRM is I believe the best of any B450 board. Only stepping up to the X chipsets will I get better VRM… but still I am not really looking to overclock this alot (I don´t even plan to replace the stock cooler of the 2700X).
Thanks for the X470 suggestion, though it is very unlikely that I am going to go for it.
The vrm on pretty much any B450 board isn´t really great,
except for the Msi itx board.
So i personally don’t particulary onderstand why B450 boards,
are getting really recommend for 3900X / 3950X cpu’s really.
We have seen several tests in which the 3900X was actually tested on the Msi X570 Gaming Edge board.
And the vrm was really performing poorly 115°C,
is definitelly not good at all.
Now given that the vrm on the Tomahawk is actually using the same exact mosfets in the same configuration as the Msi X570 gaming edge wifi.
But the actual Msi x570 Gaming edge board has twice as much phases for vcore.
So i can already tell you that the tomahawk will definitelly not handle the 3900X very well.
Even if the Tomahawk has better heatsinks.
So yeah, a 2700x can use all the way from like 125A ish on load at stock clocks to like 150A ish when overclocked 1.42V.
A 3900X in that regards can easaly hit a 180A ish current draw when pushed.
So yeah i see manny people opting for the B450 boards,
in regards to a 3900X or 3950X.
But i really won’t recommend it to anybody.
The best vrm on a B450 atx board basically is the Msi B450 Gaming pro Carbon AC.
The vrm is actually the same setup as the Tomahawk max.
BUt it has twice the amount of components per phase for the vcore vrm.
But a 2700X should basically work on the Tomahawk Max board.
But like i said i could see why Msi wouldn’t add it to the compatibility list.
If Msi added the 3900X to the compatibility list,
then that would be pretty weird.
But still a 2700X should work fine.
The heatsinks on the Max are pretty good.
So i guess you would be fine with some good airflow in the case.
BUt i wouldn’t recommend a 3900X on it.
So yeah in regards to my recommendation for a decent X470 board,
if you ever have plans to upgrade to a 3900X / 3950X.
Then a board like the Asrock Taichi will indeed give you a better vrm.
And of course better pci-e expandability.
I will definitely check that out.
Though I don´t like it when I speak gibberish, I like to get my gibberish corrected.
I saw Wendell’s b450 tomahawk review and was sort of impressed, considering its a b450. Given that the max has many upgraded features the most important (to me) of which is the improved memory capability, I thought i’d actually get a better board for less price (such is the case in my country).
Thanks, I will definitely look into the pro Carbon. I know its not your recommendation necessarily, but given that I will only sporadically be mildly overclocking… I can´t really see my conduct damaging the board. But you seem to know more of VRM’s on both boards than myself.
Yeah well i´m not native English so i kinda have to edit my posts,
for typing errors lol.
But still like i said the Tomahawk max should be okay for a 2700X.
I think it wouldn’t that much of a problem.
Especially not when you use in a decent case with a good airflow.
It’s definitelly one of the better B450 boards out there.
At least when it comes to its actual heatsinks.
I mean for the money you cannot really complain.
and if you just run the 2700X stock out of the box,
then it should be totally fine really.
Like you said you are not aiming to push it like crazy.
So it should be okay really.
I just wanted to point out, that investing in a better board,
for eventual future cpu upgrades might be something to consider.
However if you are just looking for a killer bang for buck rig.
Then its fine really.
Well yeah that might be something to consider as well indeed.
The 3600X pretty nice chip low on power consumption.
And would be pretty good when the system is mainly used for gaming.
I already have the 2700X. It was a birthday gift from my girlfriend not really going to sell it and get another chip. + I am going to use it as an entry level workstation + streaming myself play chess and using stockfish chess engine (which seems to scale well the more cores one has)
Also a pretty sweet gift that you definitelly shouldn’t sell.
Because it would be very likely that she would get angry about that haha
But yeah either pick the Tomahawk Max or the Gaming pro Carbon AC.
And have a good time with the system really.
