Comparing r9 290 GPUs
I have been working on a parts list for awhile now and I think I have almost completed my research!
Over the last couple of weeks, I have been deciding on what GPU I wanted. With some help from the Tek Syndicate community, I decided on the Radeon r9 290
The card recomended to me was the Gigabyte Radeon R9 290 4GB WINDFORCE Video Card
I am working on a Red/Black build and I was wondering if the MSI Radeon R9 290 4GB TWIN FROZR Video Card would work as well as (or better than) the Gigabyte.
I am planning on overclocking. If you have any questions about my build in regards to the GPU, here is my build:
http://pcpartpicker.com/p/HJ7Wzy
Yes it would work the same. They are basically the exact same card, if the colors are worth the extra money, I'd say go for it :)
Actually, I would recommend it, the Windforce cards are rather loud imo.
Thanks! I added the MSI GPU to my build :)
I would go msi.  they usually have military quality parts
I would urge caution on the MSI twin frozer - only reason being is that recently I've been hearing more consistently that those cards have some issues with cooling, throttling and that they aren't very good OCers. Don't take my word for it, but do some research and see what the general consensus is.
Personally, I'm considering the club3d Royal Ace R9-290, which has been receiving really good reviews across the board and is apparently one of, if not, the fastest 290 variant in terms of stock and OCing.
Here's a link to the product page: http://www.club-3d.com/index.php/products/reader.en/product/radeon-r9-290-royalace.html
And here's a recent in-depth review: https://www.youtube.com/watch?v=9DQYp6VU58Y
It'll match your red/black colour theme too. ;)
R9-290 in terms of Audio Levels and Temperatures the one i would recommend is any of the Sapphire cards. for some reason honestly a lot of vendors have issues with the coolers, where they still jump in the mid 80's in temps or still with in the high 80s. but Sapphires Tri-X cooler and Vapor-X has kept them incredibly the temps incredibly low.
I Recommend the Vapor-X card cause for the awesome Low Temps it keeps the card under and the cooler is really quiet as well.
http://www.newegg.com/Product/Product.aspx?Item=N82E16814202103&cm_re=R9-290-_-14-202-103-_-Product
Hmmmm.... I guess I am more confused now about what to choose. It sounds like I have three good options:
Sapphire Radeon R9 290 4GB Vapor-X Video Card
Radeon R9 290 royalAce
Now... Which one out of the three do you recommend? I am leaning toward the MSI, but I am open to suggestions or even other brands.
One thing :
Gygabyte cards spin the fans up at full speed when the computer starts ; I find it very irritating.
I would choose the sapphire .Or you can find a 290 stock very cheap and watercool / add you own cooler.
Honestly the Vapor-X card. and the only reason I do recommend that card is because Sapphire honestly was the only Vendor who actually were able to keep the temps of the card down, Excluding MSI on the R9-290x Lightning that was ridiculous. Usually MSI or ASUS are the ones to REALLY keep the Radeon card Temps down but for some reason these Hawaii GPU's they actually couldn't do it, and Gigabyte they are capable of Getting the Temps down but you have to raise the Fan Profiles to about 70% and that's fairly loud to begin with. but from what i've been reading, and hearing the Vapor-X card is probably the best you can grab for the R9-290.
Well, I guess this is me being OCD, but the Sapphire is light blue :( It would look really strange in a Red/Black build.
What temperature would the MSI graphics card run at?
Sorry for the nitpicking!
Go with the MSI. From the reviews I've seen the temps are from 75-85 degrees for temps and around the low 40s decibles at load, which is very quiet. Won't be completely silent, but with headphones, it'll be fine.
Plus the red/black color scheme will match your rig, which to me is worth the ever so slight performance differences between the higher end 3rd party coolers.
if you check this guys youtube channel, he  compairs alot of 290 models.
http://www.youtube.com/channel/UCNBQvT7zlLuK-hqRtv1j47g
http://www.youtube.com/watch?v=ny2xtrT4AiU
http://www.youtube.com/watch?v=pYxmW4JiJs8
http://www.youtube.com/watch?v=iN2sXD43xH0
http://www.youtube.com/watch?v=TPgEIxT6gqA
http://www.youtube.com/watch?v=C4gI26fPRJw
Long story short, the Sapphire Vapor X And Sapphire TriX are the best.
The powercolor pcs seems to be the faster at stock then the Sapphire TriX. However ive read elsewhere that there are some issues with it.
No Club3d love... :(
Those Tri-X and Vapor X are darn nice cards, no doubt. Just make sure they fit in your case! ;)
Well ive readed, that those Club 3D royal ACE cards are not bad. in terms of performance. But they are not as quiet as the sapppi´s.
Reference will do me fine, considering i plan on using a kraken g 10 and a small aio. With fans of my choice, it will be quiet and cool. I would hate to have to rip off all those fancy coolers off the new cards but i will if i must. :")~
Makes me wonder... There are lots of cheap 290's on the local classifieds here but they are mostly reference cooled (jet-engine) cards. Knowing how loud they are, might be worth it to throw a low-cost AIO cooler on it but that might not fit in the Node 304...
Trick is having a case where you can mount them as a exhaust. In my azza i can mount two to the top exhaust pretty easy .
Yeah, just had my Node 304 open this evening cleaning out the dust filters and it looks like I could fit the NZXT Kraken G10 GPU bracket with any of the compatible 140mm AIO coolers, but would come very close to interfering with the CPU cooler - which I'd also like to upgrade to something more efficient and quiet. Can only do so much in such a small case, but I'm sure I'll figure something out. Still love the small form factor, none-the-less. It's amazing what can be stuffed in these little boxes. :)
The MSI cards do this as well. They ramp up to 100% in reverse to pull any loose dust out of the heat-sink and expel it. Annoying; kinda, good for the overall longevity of the card; hell yes.
but agreed water cool that bad boy if you can.
