Hey guys, currently looking into building my first ever PC and I need some advice on which build I should go with. Two buddies of mine sent me two different builds and I could use your advice on which one to go with as well as any changes you would recommend.
Build is mostly going to be used for gaming/light streaming. Nothing else really.
I would say get the fx 8350 build since its great at streaming and AMD need all the support they can get,but the i5-4670k build is better overall.Also if you go with the fx 8350 build get 16gbs of 1866mhz ram since it will help with streaming,and if you go with the intel build get a z97 motherboard so you can have access to the new technologies.
