I’m building a new workstation and would appreciate some advice. It’s been a decade since I built a PC and a lot has changed.
I mostly do embedded software development and some amateur photo/video work. Also Kicad and some other CAD apps (Freecad at the moment). I need to run VMs in VirtualBox often. OS will be Windows 11, already have a licence.
I will use the CPU’s built in GPU initially, and look at a GPU later perhaps. I only really need to drive 2x 4k monitors, and do video encoding. Later I may look at light AI.
2.5G ethernet is desired. No Intel CPUs. It will live under my desk, probably hung in a bracket.
I already have all peripherals I need. I also have a 550W Be Quiet PSU that is only about a year old. Budget is around £1500, UK based.
My current plan is:
Ryzen 7 7700X
Asus TUF GAMING B650M-PLUS WIFI Micro ATX
DDR5 6800 RAM, 2x32GB
2x Samsung 980 Pro 2 TB M.2-2280
I need to pick a case. I want compact - I don’t game and will never need a massive GPU. I will probably want PCIe USB cards though, as I need a lot of ports and hubs only get you so far. Hence mATX instead of ITX.
General question - is this a good config? For most of what I do, multicore performance is most important, and having lots of RAM. NVMe performance is important too. Stability above all.
I need a CPU cooler. Gamers Nexus recommends the Thermalright Peerless Assassin 120. I could get an AIO if it would help with sustained loads, but I guess I’ll need a slightly larger case then.
I was considering the ASUS Prime AP201, but need to do more research. Dust is a massive problem here so I’m wondering if filters might be a good idea, or if I should just unplug everything and periodically blast it with compressed air.
I’ve probably missed something, but this is long already, so thanks for reading!
