Comp build
http://pcpartpicker.com/user/ct257/saved/kPbRsY
what is not listed is my ram,hard drive,and opticle drive as i would use the ones i have in my current comp, as well as my current keyboard,mouse,and 32 inch HDTV.
the case because on part picker they did not have the updated version of the case with usb 3.0
http://www.newegg.com/Product/Product.aspx?Item=N82E16811156254
this will be for gaming at 1080p at high,  what i need to know is if there will be bottle necking issues with my cpu and gpu
i will not be overclocking
$633.33 is the total on new egg with everything i have chosen i want to keep it under $700
Intel Core i5-4690 3.5GHz Quad-Core
Cooler Master Hyper TX3 54.8 CFM Sleeve Bearing CPU Cooler
MSI Z97 PC MATE ATX LGA1150 Motherboard
G.Skill Sniper Series 8GB (2 x 4GB) DDR3-1866 Memory CL9  1.5v
MSI Radeon R9 280 3GB TWIN FROZR Video Card
Corsair SPEC-03 White ATX Mid Tower Case
Corsair Builder 600W 80+ Bronze Certified ATX Power Supply
Microsoft Windows 8.1 (OEM) (64-bit)
more powerful and higher quality components including ram and OS and CPU cooler that you did not have ............$701.72
http://pcpartpicker.com/p/KXTzHx
If you don't need the OS get an R9 290 GPU for the difference
