im looking for something with at least 6 3.5 drive bays. 2+ 2.5 bays/mounts. 0 5.25
cooling.
preferably 360/420 front fan config.
not bothered about top mounted fans as im sick of my case being a dust magnet at the back. (antec 902 )
filterd front and bottom intakes.
price up to $170/£150, including shipping.
The larger BeQuiet cases have quite some internal space for 3.5" and allow for 360/420(?) radiators front+top. Darkbase 900 was on my radar last year, but I built a server instead and thus don’t need any drive capacity ever again. I think I calculated 10x3.5" drives + 2x360mm radiator would fit into that case.
You can even fill the 5.25" slots with IcyDock bays for even more drives+hotswap. Even on other cases, their 3slot 5.25" to 4x 3.5" drive bay is still tempting for me.
You can easily go old school and buy something like NZXT H440(H442 is updated better version).
It doesn’t have bottom intake but the rest is perfectly fine…
If you use 5.25" slots, they block the fans. So either 420 or 360 depending on your configuration.
I’ve seen Wendell using that case and Gamers Nexus had a good review on it too. Also can house all the E-ATX Threadripper boards.
But as alternative…search for cases with 6+ 5.25" slots if you dont want to go full server chassis but still want Hotswap across the board for 8 drives with IcyDock or similar products
Most cases can accommodate upteen 3.5 drives… but you may need to purchase the sleds
Fractal Define 7/7XL
BeQuiet 600/800/900 series
Phanteks P600 / EvolX series
Silverstone SSTCS380* [hot swappable trays; not radiator friendly]
Fractal Node 804* [240mm AIO support; mATX max]
