Color Schemed Motherboard / Systems?
what do you think of this idea? If Color Scheme was Important to you. what if Motherboard Manufacturers made motherboards but gave you the option to have different color schemes. something you personally wanted? like what if you're on a budget but you wanted a red and black color schemed motherboard. the only thing you're stuck with is ASUS's ROG Series. or if you wanted black and pink? or black and white whatever you really fancy that reflects you.
would you like it or dislike it? or you just dont care as long as you even have your system?
do you think this is an awesome idea?
My build is all red and black once I  replace the fans on my heatsink.
Need more white pcb's.
Also need more components matching noctuas. Those fans look amazing. I don't really care what anybody says.
I've already owned two ROG mobos and that colour scheme gets boring.
bringing myself back to the topic I think it would be cool provided it wasn't implemented very tacky.
This is an amazing idea. I would totally buy a Maximus VI Formula if it fit with my blue/black colour scheme.
Also, if you needed a red/black mobo, you could get the something from the MSI Gaming line.
I don't care about it because i don't like windowed cases.
It would be great for people who are using a windowed case tho.
