I just enrolled to Mechanical engineering college and I need to build a machine on a budget (400$-550$) and I don't have a lot of experience when it comes to hardware (this is an understatement).
I have the peripherals from my old pc (might change the monitor if needed).
This computer must be capable to work with programs such as AutoCad, Photoshop, various file conversion and simulation programs (Piping and fluid flow, Heat transfer and other types of simulations). It will also be used for a lot of programing, possible for a little bit of gaming, mostly Minecraft and Portal 2.
It's possible that I will add more peripherals such as 2D and 3D scanners, 3D printer and a laser cutter in the future.
