Coarsair K65 Keyboard help [SOLVED]
Okay so I've only had this keyboard for like 2 months and Like 5 keys won't display red. Is the red LED dead or is this a software issue? Instead of red it displays an off green color)
If they display the rest of the color range fine, I'd guess it's a problem with the LEDs themselves. I don't know what the software does, but if you have an updated version and set all the profiles to default it could help you troubleshoot.
I think it's an LED problem. Sucks. I really liked this keyboard too. ;-;
Are you still under warranty? Isn't the standard warranty like 90 days or something? At any rate the keyboard itself still functions yea? Change your theme to off-green? lol ( I know that's not worth doing if you have a red themed build or something, just trying to be optimistic.)
