Today i had problems with Java and not being able to open or run .Jar files, After a little research i changed the PATH file in environmental variable, Java 32 bit was called CLASSPATH and i had some nvidia file as a variable PATH and i replaced it with java 64 bit. It did fix the problem i was having but then later on if i entered any command into CMD it would say "Is not recognized as an internal or external command, Operable program or batchfile" And i carnt work out why.
I fear that ive probably broken something. Any help would be great.
