CM Stacker
Hello, I have seen the CM HAF stacked and I want to use one for my pc then the bottom case for hard drives and maybe cooling then the mid tower part for my pc then the top case for another pc for friends to play on (so we can game together) but are they any good or are they're better solutions? Thanks (sorry if my spelling is messed up, my HP touchpad auto correct like crazy)
The CM Stacker is aimed at exactly what you are doing. It is cheap which is a plus and has good airflow. You will find yourself hard pressed to fin a better case combo for that price, you just need to make sure you get the correct accessories:
*Need a top for your case and a bottom for the Guest PC
*Need the top case to have the front panel I/O
I know the combo (the top and mid cases) on amazon cost $169.99 then another $69.99 for the bottom case, but thanks for the help!
http://pcpartpicker.com/part/cooler-master-case-haf935kwn1
There are cheaper places to buy from, or are you stuck with Amazon?
Edit: The 915R looks to be 64.99 at microcenter too.
I'm not stuck with amazon, but thanks.
