As the title says the pump on my Cool Master Glacer 240L is running at 4.4k RPM and the pump says it only goes to 3.5k RPM. This started last night when i first booted my computer and the pump instantly started with this RPM, it is insanely loud and annoying. I am using Asus Fan Xpert to control fans (Speed Fan causes BSOD) but it reads the pump at all % while tuning to be over 4k RPM and i can not adjust it through there. Is there a way i can adjust the voltage going to my fan header so i can drop the pump speed down?
System Spec
OS: Windows 8.1 64 bit
BIOS: Version 2.10.1208.
MOBO: Asus Maximus VI Hero
CPU: Intel i7 4770K
RAM: 8GB G.Skill Ripjaws X series
GPU: Asus Direct CUII OC GTX 780
PSU: Corsair AX760W
HDD: Kingston Hyper X 120gb
1TB Mechanical Drive
