CM 690 II Advanced and liquid cooling
So I posted a while back about my future gaming rig. It's changed a little bit since then and instead of a Corsair 550D I decided to go with a Cooler Master 690 II Advanced(Cheaper and looks better imo). I also decided to get a Corsair H100i to cool the CPU. And this brings me to my question. Can the CM 690 II Advanced accommodate a dual rad up top with 4 fans in a Push/Pull configuration?
I know I can fit a 240mm rad on the bottom(Push/Pull) but I was wondering if I could do that in the top aswell.
Google image Cooler master 690 ii liquid cooling.
The second thing says it can fit two rad's if that helps.
