Closed Loop Water Coolers
Hi, what is the best (as in most expensive and biggest) closed loop water cooler to fit inside the Fractal Design Define R4 Black Pearl Midi Tower Window Soundproof Case. i really want this case but not sure what cooler will fit inside :) cheers guys :D
Swiftech H220 is the best CPU cooler out there (that is sealed).
cheers dude!
It's also expandable so you can add a GPU, more radiators ETC. to the loop if you want.
