Fedora 23 installed on my second hdd
Will not detect my wifi card
Wifi card is a Broadcom 43228 mini pcie card.
Tethered my phone.
Tell me what you need to help me fix it and i can paste terminal outputs here.
Tethered my phone.
does the card work in any other computers/os's?
what type of phone is it? iphone? android? blackberry? other?
https://onpub.com/install-broadcom-linux-wi-fi-driver-on-fedora-23-s7-a192
1 sec on google
propriety drivers so you need to install them in some way. dont know if above works but you can always use rpmfusion and install broadcom-wl
since you seem new to fedora check something like this out, if you care about free software you would have to change your wifi card
24 Things to Do After Fresh Installation of Fedora 23 Workstation
cheers
Yes the card works in Windows - its the built in card on my Maximus V Formula Mobo
My phone is just tethered for internet purposes
RPMFusion is enabled and i hyave installed kmod-wl and the broadcom-wl drivers.
here is the lspci output
[root@localhost Vandal]# lspci
00:00.0 Host bridge: Intel Corporation Xeon E3-1200 v2/3rd Gen Core processor DRAM Controller (rev 09)
00:01.0 PCI bridge: Intel Corporation Xeon E3-1200 v2/3rd Gen Core processor PCI Express Root Port (rev 09)
00:14.0 USB controller: Intel Corporation 7 Series/C210 Series Chipset Family USB xHCI Host Controller (rev 04)
00:16.0 Communication controller: Intel Corporation 7 Series/C210 Series Chipset Family MEI Controller #1 (rev 04)
00:19.0 Ethernet controller: Intel Corporation 82579V Gigabit Network Connection (rev 04)
00:1a.0 USB controller: Intel Corporation 7 Series/C210 Series Chipset Family USB Enhanced Host Controller #2 (rev 04)
00:1b.0 Audio device: Intel Corporation 7 Series/C210 Series Chipset Family High Definition Audio Controller (rev 04)
00:1c.0 PCI bridge: Intel Corporation 7 Series/C210 Series Chipset Family PCI Express Root Port 1 (rev c4)
00:1c.4 PCI bridge: Intel Corporation 7 Series/C210 Series Chipset Family PCI Express Root Port 5 (rev c4)
00:1c.6 PCI bridge: Intel Corporation 7 Series/C210 Series Chipset Family PCI Express Root Port 7 (rev c4)
00:1c.7 PCI bridge: Intel Corporation 7 Series/C210 Series Chipset Family PCI Express Root Port 8 (rev c4)
00:1d.0 USB controller: Intel Corporation 7 Series/C210 Series Chipset Family USB Enhanced Host Controller #1 (rev 04)
00:1f.0 ISA bridge: Intel Corporation Z77 Express Chipset LPC Controller (rev 04)
00:1f.2 SATA controller: Intel Corporation 7 Series/C210 Series Chipset Family 6-port SATA Controller [AHCI mode] (rev 04)
00:1f.3 SMBus: Intel Corporation 7 Series/C210 Series Chipset Family SMBus Controller (rev 04)
01:00.0 VGA compatible controller: NVIDIA Corporation GM204 [GeForce GTX 980] (rev a1)
01:00.1 Audio device: NVIDIA Corporation GM204 High Definition Audio Controller (rev a1)
02:00.0 PCI bridge: ASMedia Technology Inc. ASM1083/1085 PCIe to PCI Bridge (rev 03)
03:04.0 Multimedia audio controller: C-Media Electronics Inc CMI8788 [Oxygen HD Audio]
04:00.0 USB controller: ASMedia Technology Inc. ASM1042 SuperSpeed USB Host Controller
05:00.0 PCI bridge: PLX Technology, Inc. PEX 8608 8-lane, 8-Port PCI Express Gen 2 (5.0 GT/s) Switch (rev ba)
06:01.0 PCI bridge: PLX Technology, Inc. PEX 8608 8-lane, 8-Port PCI Express Gen 2 (5.0 GT/s) Switch (rev ba)
06:04.0 PCI bridge: PLX Technology, Inc. PEX 8608 8-lane, 8-Port PCI Express Gen 2 (5.0 GT/s) Switch (rev ba)
06:05.0 PCI bridge: PLX Technology, Inc. PEX 8608 8-lane, 8-Port PCI Express Gen 2 (5.0 GT/s) Switch (rev ba)
06:06.0 PCI bridge: PLX Technology, Inc. PEX 8608 8-lane, 8-Port PCI Express Gen 2 (5.0 GT/s) Switch (rev ba)
06:07.0 PCI bridge: PLX Technology, Inc. PEX 8608 8-lane, 8-Port PCI Express Gen 2 (5.0 GT/s) Switch (rev ba)
06:08.0 PCI bridge: PLX Technology, Inc. PEX 8608 8-lane, 8-Port PCI Express Gen 2 (5.0 GT/s) Switch (rev ba)
06:09.0 PCI bridge: PLX Technology, Inc. PEX 8608 8-lane, 8-Port PCI Express Gen 2 (5.0 GT/s) Switch (rev ba)
09:00.0 SATA controller: ASMedia Technology Inc. ASM1062 Serial ATA Controller (rev 01)
0c:00.0 Network controller: Broadcom Corporation BCM43228 802.11a/b/g/n
0e:00.0 SATA controller: ASMedia Technology Inc. ASM1062 Serial ATA Controller (rev 01)
Can you post the output of lspci -vnn
[Vandal@localhost ~]$ lspci -vnn
00:00.0 Host bridge [0600]: Intel Corporation Xeon E3-1200 v2/3rd Gen Core processor DRAM Controller [8086:0150] (rev 09)
Subsystem: ASUSTeK Computer Inc. P8 series motherboard [1043:84ca]
Flags: bus master, fast devsel, latency 0
Capabilities:
Kernel driver in use: ivb_uncore
Kernel modules: ie31200_edac
00:01.0 PCI bridge [0604]: Intel Corporation Xeon E3-1200 v2/3rd Gen Core processor PCI Express Root Port [8086:0151] (rev 09) (prog-if 00 [Normal decode])
Flags: bus master, fast devsel, latency 0, IRQ 24
Bus: primary=00, secondary=01, subordinate=01, sec-latency=0
I/O behind bridge: 0000e000-0000efff
Memory behind bridge: f6000000-f70fffff
Prefetchable memory behind bridge: 00000000e0000000-00000000f1ffffff
Capabilities:
Kernel driver in use: pcieport
Kernel modules: shpchp
00:14.0 USB controller [0c03]: Intel Corporation 7 Series/C210 Series Chipset Family USB xHCI Host Controller [8086:1e31] (rev 04) (prog-if 30 [XHCI])
Flags: bus master, medium devsel, latency 0, IRQ 36
Memory at f7620000 (64-bit, non-prefetchable) [size=64K]
Capabilities:
Kernel driver in use: xhci_hcd
00:16.0 Communication controller [0780]: Intel Corporation 7 Series/C210 Series Chipset Family MEI Controller #1 [8086:1e3a] (rev 04)
Flags: bus master, fast devsel, latency 0, IRQ 44
Memory at f763b000 (64-bit, non-prefetchable) [size=16]
Capabilities:
Kernel driver in use: mei_me
Kernel modules: mei_me
00:19.0 Ethernet controller [0200]: Intel Corporation 82579V Gigabit Network Connection [8086:1503] (rev 04)
DeviceName: Onboard LAN
Subsystem: ASUSTeK Computer Inc. P8P67 Deluxe Motherboard [1043:849c]
Flags: bus master, fast devsel, latency 0, IRQ 42
Memory at f7600000 (32-bit, non-prefetchable) [size=128K]
Memory at f7639000 (32-bit, non-prefetchable) [size=4K]
I/O ports at f040 [size=32]
Capabilities:
Kernel driver in use: e1000e
Kernel modules: e1000e
00:1a.0 USB controller [0c03]: Intel Corporation 7 Series/C210 Series Chipset Family USB Enhanced Host Controller #2 [8086:1e2d] (rev 04) (prog-if 20 [EHCI])
Flags: bus master, medium devsel, latency 0, IRQ 20
Memory at f7638000 (32-bit, non-prefetchable) [size=1K]
Capabilities:
Kernel driver in use: ehci-pci
00:1b.0 Audio device [0403]: Intel Corporation 7 Series/C210 Series Chipset Family High Definition Audio Controller [8086:1e20] (rev 04)
Subsystem: ASUSTeK Computer Inc. Device [1043:8546]
Flags: bus master, fast devsel, latency 0, IRQ 45
Memory at f7630000 (64-bit, non-prefetchable) [size=16K]
Capabilities:
Kernel driver in use: snd_hda_intel
Kernel modules: snd_hda_intel
00:1c.0 PCI bridge [0604]: Intel Corporation 7 Series/C210 Series Chipset Family PCI Express Root Port 1 [8086:1e10] (rev c4) (prog-if 00 [Normal decode])
Flags: bus master, fast devsel, latency 0, IRQ 16
Bus: primary=00, secondary=02, subordinate=03, sec-latency=0
I/O behind bridge: 0000d000-0000dfff
Memory behind bridge: f2100000-f22fffff
Prefetchable memory behind bridge: 00000000f2300000-00000000f24fffff
Capabilities:
00:1c.4 PCI bridge [0604]: Intel Corporation 7 Series/C210 Series Chipset Family PCI Express Root Port 5 [8086:1e18] (rev c4) (prog-if 00 [Normal decode])
Bus: primary=00, secondary=04, subordinate=04, sec-latency=0
Memory behind bridge: f7500000-f75fffff
Capabilities:
00:1c.6 PCI bridge [0604]: Intel Corporation 7 Series/C210 Series Chipset Family PCI Express Root Port 7 [8086:1e1c] (rev c4) (prog-if 00 [Normal decode])
Flags: bus master, fast devsel, latency 0, IRQ 18
Bus: primary=00, secondary=05, subordinate=0d, sec-latency=0
I/O behind bridge: 0000c000-0000cfff
Memory behind bridge: f7100000-f73fffff
Capabilities:
00:1c.7 PCI bridge [0604]: Intel Corporation 7 Series/C210 Series Chipset Family PCI Express Root Port 8 [8086:1e1e] (rev c4) (prog-if 00 [Normal decode])
Flags: bus master, fast devsel, latency 0, IRQ 19
Bus: primary=00, secondary=0e, subordinate=0e, sec-latency=0
I/O behind bridge: 0000b000-0000bfff
Memory behind bridge: f7400000-f74fffff
Capabilities:
00:1d.0 USB controller [0c03]: Intel Corporation 7 Series/C210 Series Chipset Family USB Enhanced Host Controller #1 [8086:1e26] (rev 04) (prog-if 20 [EHCI])
Flags: bus master, medium devsel, latency 0, IRQ 23
Memory at f7637000 (32-bit, non-prefetchable) [size=1K]
Capabilities:
00:1f.0 ISA bridge [0601]: Intel Corporation Z77 Express Chipset LPC Controller [8086:1e44] (rev 04)
Capabilities:
Kernel driver in use: lpc_ich
Kernel modules: lpc_ich
00:1f.2 SATA controller [0106]: Intel Corporation 7 Series/C210 Series Chipset Family 6-port SATA Controller [AHCI mode] [8086:1e02] (rev 04) (prog-if 01 [AHCI 1.0])
Flags: bus master, 66MHz, medium devsel, latency 0, IRQ 33
I/O ports at f090 [size=8]
I/O ports at f080 [size=4]
I/O ports at f070 [size=8]
I/O ports at f060 [size=4]
I/O ports at f020 [size=32]
Memory at f7636000 (32-bit, non-prefetchable) [size=2K]
Capabilities:
Kernel driver in use: ahci
00:1f.3 SMBus [0c05]: Intel Corporation 7 Series/C210 Series Chipset Family SMBus Controller [8086:1e22] (rev 04)
Flags: medium devsel, IRQ 18
Memory at f7635000 (64-bit, non-prefetchable) [size=256]
I/O ports at f000 [size=32]
Kernel modules: i2c_i801
01:00.0 VGA compatible controller [0300]: NVIDIA Corporation GM204 [GeForce GTX 980] [10de:13c0] (rev a1) (prog-if 00 [VGA controller])
Subsystem: eVga.com. Corp. Device [3842:2983]
Flags: bus master, fast devsel, latency 0, IRQ 43
Memory at f6000000 (32-bit, non-prefetchable) [size=16M]
Memory at e0000000 (64-bit, prefetchable) [size=256M]
Memory at f0000000 (64-bit, prefetchable) [size=32M]
I/O ports at e000 [size=128]
Expansion ROM at f7000000 [disabled] [size=512K]
Capabilities:
Kernel driver in use: nouveau
Kernel modules: nouveau
01:00.1 Audio device [0403]: NVIDIA Corporation GM204 High Definition Audio Controller [10de:0fbb] (rev a1)
Flags: bus master, fast devsel, latency 0, IRQ 17
Memory at f7080000 (32-bit, non-prefetchable) [size=16K]
Capabilities:
02:00.0 PCI bridge [0604]: ASMedia Technology Inc. ASM1083/1085 PCIe to PCI Bridge [1b21:1080] (rev 03) (prog-if 00 [Normal decode])
Bus: primary=02, secondary=03, subordinate=03, sec-latency=64
Capabilities:
03:04.0 Multimedia audio controller [0401]: C-Media Electronics Inc CMI8788 [Oxygen HD Audio] [13f6:8788]
Subsystem: ASUSTeK Computer Inc. Virtuoso 100 (Xonar Essence STX) [1043:835c]
Flags: bus master, medium devsel, latency 64, IRQ 16
I/O ports at d000 [size=256]
Capabilities:
Kernel driver in use: snd_virtuoso
Kernel modules: snd_virtuoso
04:00.0 USB controller [0c03]: ASMedia Technology Inc. ASM1042 SuperSpeed USB Host Controller [1b21:1042] (prog-if 30 [XHCI])
Subsystem: ASUSTeK Computer Inc. P8B WS Motherboard [1043:8488]
Memory at f7500000 (64-bit, non-prefetchable) [size=32K]
Capabilities:
05:00.0 PCI bridge [0604]: PLX Technology, Inc. PEX 8608 8-lane, 8-Port PCI Express Gen 2 (5.0 GT/s) Switch [10b5:8608] (rev ba) (prog-if 00 [Normal decode])
Flags: bus master, fast devsel, latency 0, IRQ 25
Memory at f7300000 (32-bit, non-prefetchable) [size=128K]
Bus: primary=05, secondary=06, subordinate=0d, sec-latency=0
Memory behind bridge: f7100000-f72fffff
Capabilities:
06:01.0 PCI bridge [0604]: PLX Technology, Inc. PEX 8608 8-lane, 8-Port PCI Express Gen 2 (5.0 GT/s) Switch [10b5:8608] (rev ba) (prog-if 00 [Normal decode])
Flags: bus master, fast devsel, latency 0, IRQ 26
Bus: primary=06, secondary=07, subordinate=07, sec-latency=0
Capabilities:
06:04.0 PCI bridge [0604]: PLX Technology, Inc. PEX 8608 8-lane, 8-Port PCI Express Gen 2 (5.0 GT/s) Switch [10b5:8608] (rev ba) (prog-if 00 [Normal decode])
Flags: bus master, fast devsel, latency 0, IRQ 27
Bus: primary=06, secondary=08, subordinate=08, sec-latency=0
Capabilities:
06:05.0 PCI bridge [0604]: PLX Technology, Inc. PEX 8608 8-lane, 8-Port PCI Express Gen 2 (5.0 GT/s) Switch [10b5:8608] (rev ba) (prog-if 00 [Normal decode])
Flags: bus master, fast devsel, latency 0, IRQ 28
Bus: primary=06, secondary=09, subordinate=09, sec-latency=0
Memory behind bridge: f7200000-f72fffff
Capabilities:
06:06.0 PCI bridge [0604]: PLX Technology, Inc. PEX 8608 8-lane, 8-Port PCI Express Gen 2 (5.0 GT/s) Switch [10b5:8608] (rev ba) (prog-if 00 [Normal decode])
Flags: bus master, fast devsel, latency 0, IRQ 29
Bus: primary=06, secondary=0a, subordinate=0a, sec-latency=0
Capabilities:
06:07.0 PCI bridge [0604]: PLX Technology, Inc. PEX 8608 8-lane, 8-Port PCI Express Gen 2 (5.0 GT/s) Switch [10b5:8608] (rev ba) (prog-if 00 [Normal decode])
Flags: bus master, fast devsel, latency 0, IRQ 30
Bus: primary=06, secondary=0b, subordinate=0b, sec-latency=0
Capabilities:
06:08.0 PCI bridge [0604]: PLX Technology, Inc. PEX 8608 8-lane, 8-Port PCI Express Gen 2 (5.0 GT/s) Switch [10b5:8608] (rev ba) (prog-if 00 [Normal decode])
Flags: bus master, fast devsel, latency 0, IRQ 31
Bus: primary=06, secondary=0c, subordinate=0c, sec-latency=0
Memory behind bridge: f7100000-f71fffff
Capabilities:
06:09.0 PCI bridge [0604]: PLX Technology, Inc. PEX 8608 8-lane, 8-Port PCI Express Gen 2 (5.0 GT/s) Switch [10b5:8608] (rev ba) (prog-if 00 [Normal decode])
Flags: bus master, fast devsel, latency 0, IRQ 32
Bus: primary=06, secondary=0d, subordinate=0d, sec-latency=0
Capabilities:
09:00.0 SATA controller [0106]: ASMedia Technology Inc. ASM1062 Serial ATA Controller [1b21:0612] (rev 01) (prog-if 01 [AHCI 1.0])
Subsystem: ASUSTeK Computer Inc. Device [1043:84b7]
Flags: bus master, fast devsel, latency 0, IRQ 34
I/O ports at c050 [size=8]
I/O ports at c040 [size=4]
I/O ports at c030 [size=8]
I/O ports at c020 [size=4]
I/O ports at c000 [size=32]
Memory at f7200000 (32-bit, non-prefetchable) [size=512]
Capabilities:
0c:00.0 Network controller [0280]: Broadcom Corporation BCM43228 802.11a/b/g/n [14e4:4359]
Subsystem: ASUSTeK Computer Inc. Device [1043:850c]
Flags: bus master, fast devsel, latency 0, IRQ 11
Memory at f7100000 (64-bit, non-prefetchable) [size=16K]
Capabilities:
Kernel modules: bcma
0e:00.0 SATA controller [0106]: ASMedia Technology Inc. ASM1062 Serial ATA Controller [1b21:0612] (rev 01) (prog-if 01 [AHCI 1.0])
Flags: bus master, fast devsel, latency 0, IRQ 35
I/O ports at b050 [size=8]
I/O ports at b040 [size=4]
I/O ports at b030 [size=8]
I/O ports at b020 [size=4]
I/O ports at b000 [size=32]
Memory at f7400000 (32-bit, non-prefetchable) [size=512]
Capabilities:
Try doing sudo modprobe wl this should load the module and sudo systemctl restart NetworkManager see if now works.
To load the wl module at boot do:
echo 'wl' | sudo tee /etc/modules-load.d/wl.conf
[Vandal@localhost ~]$ sudo modprobe wl
modprobe: FATAL: Module wl not found in directory /lib/modules/4.2.6-301.fc23.x86_64
Did you install the devel packages beforehand? sudo dnf install kernel-devel
Edit: or simply do:sudo dnf update --best --allowerasing then akmods --force and then sudo modprobe wl
yeah kernel-devel has been installed from the start
even after all that I still get
Replace kmod-wl with akmod-wl then run the two commands sudo akmods --force and then sudo modprobe wl then restart the networkmanager service.
Still no luck
Going to bed, need my sleep so I can keep beating my head against a wall tomorrow.
Thanks for the help
No problem. We'll get it installed. I have 2 pcs with Broadcom wifi cards so... :)
Edit: when you wake up post the outputs of uname -r and rpm -qa | grep -e kernel -e broadcom-wl -e kmod-wl | sort replace kmod-wl with akmod-wl if you have akmod-wl.
Wait you marked it at solved. Did you get it working?
