I need to reinstall my h100i gtx and that means replacing the thermal paste, I don't have any isopropyl alcohol on hand which I read is good for cleaning CPUs, would just wiping the paste off which paper towel until both surfaces are clean work as I am not doing any crazy over locking.
I wouldn't use something like paper towel that may leave something behind. A good cotton cloth made of an old shirt (for example) will work really good.
No, you don't but you'll need some helbow grease and to wipe it until the cloth stays clean. I did that because I couldn't get my hands on isopropyl alchool where I live and worked great. Also over time your CPU heatspreader will get shinier over time.
Acetone works fine too, you should be able to get it at any hardware store. Chemists often have isopropyl alcohol, or rubbing alcohol as it's often called. Try to get something with a high concentration, I have a bunch of isopropyl wipes which are 70% which work fine, but the 99% stuff will dry off almost instantly which makes it easier to apply fresh paste.
This seems like much ado about nothing imo... rubbing alcohol, strong drinks, etc. along w/ a coffee filter or another material that won't leave any residue. (srsly u don't have rubbing alcohol?).
