Cleaning Monitor
Hello guys what do you guys use to clean your monitor?
Get a soft paper towel, spray some window cleaner onto it, wipe it down, get another paper towel, take off any residue, remove any streaks.
People will freak out and tell you that paper towels will scratch it and glass cleaner will react with some fancy chemical coating and decay it, but that's just people overhyping it.  Just use your brain and avoid things like industrial strength Windex and brown paper towels, and you're golden. Something like Invisible Glass is ammonia free and works great.
Ok thank you.
