Hey is there a possibility that you guys could make a video on how to clean a graphics card. I think I would not be the only one who would find this very helpful. Also I would prefer if the graphics card you cleaned was a 7970, but I think it is probably the same for them all.
Thank you!!!
SSJSTER
take the cooler off spray with compressed air slap it back on like you're applying a cpu heatsink.
You don't have to take off the heatsink. Get a can of compressed air with a plastic nozzle and get it into the heatsink. Spray. It's dirty and will leave some dust in tough places, so if you really want to be thorough, you will have to take of the heatsink.
Don't take it apart, it's a bit of a hastle dealing with replacing the thermal grease that comes with it, just get a can of compressed air and spray the shit out of it.
