So I’m trying to configure my switch. I have done the factory reset, followed the getting started guide, but I get a 404 on the web ui.
How would I go about configuring this thing via telnet? I can’t find much onlite in forum posts and I don’t exactly hawe experience with this sorta thing.
I don’t want to setup anything complicated. Just one vlan for all the ports and for it to just handle a connection in, connection out sorta deal.
I have a 48 port 10/100 model without sfp modules for 1-10G in so my liwe line, for now, will be on port 48 opposite of the clients.
Connecting via the USB console port, or the DB-9 to ethernet console port on the back are the main options. Unsure if you’re able to get to the default IP address on the switch, which I want to say was something like 172.16.0.1/16, but I may be misremembering that (I’ve always loaded a config on a factory reset switch via DB9)
secure-server is https enable
server is just http enable.
wr mem stores running config into startup config
so that if you power cycle the switch it will retain its config on next boot.
