Cinebench R15 Extreme! AND Cinebench R20 - Benchmarking Thread
[email protected] 4x8GB DDR3 1600MHz GTX 1070ftw
i9 7940x oc, 2080ti & 64G of GSkill DDR4
I’m pretty sure I need to square the edge of my CPU as it runs hot.
Full spec details at https://NerdFace.com/nerdface-tech
Nice score! What is your CPU overclock?
Dual X5650s @stock
Stock 2600x with 3200mhz 16-18-18-38
363 was my best score, seems low to me compared to the 2700x boys, but it’s probably right. Manages 4046-4060mhz on all cores. Tried the “optimized” setting for CB in bios, all it did was lower the score by 10 points.
Edit: Oh yeah, motherboard. Asus X470-F Gaming
1700X completely stock
4x4GB 2666MHz C16
RX480 8GB
Fun fact: The Open GL score move from 77,35 to 88.89fps score… While the CPU score in multiple runs have 1 point difference…
1700x @3,9 ghz OC , 16 gb 3200 mhz cl14
I guess the ram speed pays off… On top of the OC…
It mostly shows in a lot of benchmarks like 3d mark etc most of games like clockspeed more than ram speed . Did you get your new Mainboard or did you get the one working you had? :smiley:
I’m still using my old board… It have boot issue, but once it boots it’s fine. I am waiting on the 500 series boards before I buy MSI B350 Krait…
Ryzen 1700 @ 3.75Ghz. Im lazy so on linux.
What ram speed are you running at :slight_smile: ?
2666 with a bump in voltage and set to 2933 cl16.
Threadripper 2950X, XMP 3000MHz
Wine 4.1, release: 57
CPU 796 cb
CPU (Single Core) 45
Just having fun with some extremely old enthusiast/enterprise level gear.
Surprisingly not the lowest score on the board.
Ryzen 1700X at stock
First Cinebench R20 result. Hope to get more!
There is R20 now? Oh ffs…
R15 Extreme
R20
RAM speed, core clocks, motherboard model?
