Hi guys. I’ve been a long-time lurker, so this is my first actual topic. I’ve found myself in quite a predicament with failing PC’s, as if the PC gods have placed a curse on me. This will be a long story so please bare with me.
I had been using a setup for almost exclusively gaming for about a year and a half, and it was mostly played on a TV using a controller. I decided to move it to my home office room to play it the good old fashioned way with Mouse and Keyboard, and on the third day, when I turn it on it abruptly shut-off while it was booting as if there was a power outage. I hit the power button to try to turn it on again, and it slightly powered the fans for like a second and shut-off again. I began to pick up a distinct burnt smell coming from it, so I assumed something got messed up bad. After opening the Desktop, I noticed the smell was coming from the PSU which was around 5 years old, so I guessed it was time to replace it, so I did.
I buy and install a new PSU, hit the power button, and the machine powered up fine… except it wouldn’t go through POST. It just remained turned on but frozen in limbo. Fans are spinning, RGB lights are on, but no LED lights indicating errors with any hardware components, no beeps, no signal on the monitor. Also, hitting the power button while it was in this state didn’t turn it back off, not even holding it down. So I thought that massive PSU failure must have screwed up the motherboard or something else. I tried removing different components and testing, GPU, RAM, re-seating cables, nothing worked. So I RMA’d the board…
Here’s when things get really complicated. I was planning to build a secondary PC to leave it as a TV gaming setup anyway, so I took the opportunity to order a different board and an extra PSU while I got the old board replaced. I had another old case I could reuse, so I just set everything up in there. I named this machine Hex. It had basically everything from the other machine, except the motherboard and PSU. I booted it up, and noticed that my secondary HDD wasn’t being detected, but it still booted fine with the primary SSD. Looks like the HDD was killed off as well. Also, the keyboard wasn’t working… so that got screwed too (RMA’d it and got a working replacement). Anyway, I just left it as it was and reinstalled Windows and some games, and all was working fine. I was playing again. However, on it’s third day when I got home from work and was ready to play, it just wouldn’t respond to the power button… until I removed a USB stick I had left plugged-in and then it worked so I thought it was a short of some kind. Until the next day, while I was playing, it suddenly shutoff again, and it was not responding at all to the power button again. Nothing lit up, fans didn’t spin, nothing worked, nothing happened. Again I decided to curse the gods and attempt to troubleshoot by removing components, even trying the other PSU to no avail. I figured this new MoBo was probably bad as well…
But hey, at least I got the other motherboard replacement so I eagerly install it and all of the other components on the original case. I will name this PC Nexus, the one that will be my Keyboard and Mouse gaming rig. I put everything the way it was, flip the PSU switch, the RGB LED’s light up on the board, so far so good, but pressing the power button did nothing… I rechecked the Power Switch and Reset Switch cables in the board, flipped them around in case I had them backwards, and randomly it started to boot up! I was like YES! So I turn it off, plug in my peripherals, and… it’s dead again… the power button does nothing… Even though the RGB LED’s are on, and a Power LED indicator on the board is also turned on indicating that it’s getting power…
I have no idea what is happening right now. I was beginning to suspect it was the CPU, but when I remove it to try to power on the device there is no change in behavior. The power receptacles appear to work because I’ve tried plugging in a lamp and other things to it and they work fine. Also the PSU I use gives me a steady 120V input reading. So… what is this? I tried powering on Hex with only the CPU fan connected, and IT ACTUALLY TURNED ON WTF!? So is it the CPU? Is it the replacement motherboard? Is it BOTH!? Are BOTH my new PSU’s fugged? What should I try next?
I thank you for your patience in reading all this. It’s been rough. Here are the components in question
Ryzen 1700X CPU
8x2GB G.SKILL 3000Hz RAM
Samsung 970 Pro SSD (512 GB)
Original RMA’d Motherboard: Asus ROG STRIX X370-F Gaming (for Nexus)
New Motherboard: MSI Gaming Pro Carbon AC B450 (for Hex)
New PSU’s: EVGA BQ 750 W and Corsair 750 W Bronze+
Old and discarded PSU: Thermaltake 750 W Bronze+
