Chromeos for education help!
Hey yall,
So I am an English teacher in Istanbul and her ein Turkey there is basically NO installed base of Chrombooks in any market as far as I can tell, certainly not in education. All of these kids use iPads and all that they do with them is play games (well, beyond say 6th grade). So, I am trying to convince my school to give chromeos a shot. Does anyone have any advice? What do you suggest I present to them? The info that Google has on their own that I have seen, well, sucks. It’s typical marketing BS and is weak at best (I used to work in marketing so I feel fairly confident in that assessment). It’s REALLY tough to find these here for a reasonable price as well so I have been using my laptop (Dell E6430) to show off the OS with cloudready on it but then people just get the idea that ‘this guy’s just a nerd whatever’, which might be exacerbated by the fact that I also have macos, linux mint, and win10 on the same laptop…I love latitudes btw…
Anyways is there ANYONE out here who is or was in education and went through the transition from crappads to chromebooks? what did you do, what was the PROCESS that you took to make this switch? What was the cost/student? etc., etc., etc…
I have SOME infor but I am struggling to make something to present which is normie-friendly, understandable, etc., especially without even HAVING a chromebook here to use as a REAL WORLD example!!!
Anyways thanks for anything yall can help with…I am a hobbyist with an engineering degree teaching english so I really don’t know a TON about how these things would go as I have never been in IT. I would love to sound smart (read:just not TOO dumb) when I go to the IT folks with this info if possible.
I don’t have experience in education specifically, but afaik you’re basically just getting enterprise gsuite features for free; you can probably look at those docs. The other thing you can do is actually reach out to Google, and get one of the gsuite reps to answer your specific questions - not sure if you’ll be buying your Chromebooks directly from Google or from e.g. Lenovo/hp/Samsung/Acer/…
Are you already using gsuite? ie. do you have your domain set-up and your students and teachers have their accounts and so on, and you’re generally comfortably with the concepts around managing user accounts? If not, it’s kind of tough.
… or do you need help with that too?
Do you have specific questions?
Typically, once you’ve setup your domain and have accounts, and are fine in general using all the web stuff as you would from any normal machine, you can grab a bunch of Chromebooks, write down their serial numbers. On first boot, or after a wipe, you can then “enroll” them into an organization basically by signing in, which binds them (their hardware TPM certs) to your domain (they’re kind of bricks as Chromebooks until you de-enroll then from the domain, not really worth stealing in most cases since they’re to much hassle to convert into Linux laptops and serial numbers are screaming everywhere). You basically get an inventory / giant list of Chromebook machines in your Google admin console where you can tell when they were last online, some comments and so on.
Unlike typical Windows or Linux machines that get tied to an AD or work as part of some realm/domain and are managed by some agent, working alongside your precious software and data stack, there’s no such stack on Chromebooks per se. On Chromebooks you have your browser that syncs to your Google account, and some temporary storage alongside that’s unlocked as long as you’re logged in.
All temporary data is on a user partition, all updates happen in the background across a pair of partitions with A-B booting and differential updates, you just reboot once in a while which takes less than 5s typically + whatever time to enter username and password and figure out where your tabs were before reboot. Wiping/repurposing a machine takes less than 5 minutes typically.
In terms of daily interactions, it basically all revolves around email and Google groups for comms and Google drive for actual/non-temporary files, and whatever drive compatible apps you can find, and whatever apps you already have you can oauth into, and whatever webapps can get to work offline. You can install extensions/apps by policy on Chromebooks. Generally, when your Chromebook gets eaten by a dog, you can get up and running on a new one in less than 5min (basically log in + sync for a bajillion extensions + pick up your mental state in order to get going).
Is this really the crux of the problem with your school’s iPad deployment - that students primarily use them for playing games when they should otherwise be engaged in educational activities? If so, I’d say that sounds like an issue of classroom management and not the technology itself.
If there’s more to it than that it would be helpful if you could enumerate the ways in which you imagine switching from iPads to Chromebooks would genuinely improve the teaching and learning environment. Student attention management? Device management? Integration with Google services you might otherwise be using? Total cost of ownership savings? Laptop vs. tablet form factor differences? Etc.
I would send google teaching department an email similar to what you posted here. I know they push hard in other markets for chrome-os in schools. They may be able to send you marketing information and even support you in your effort.
Nothing to lose in asking.
Also, it’s probably not out of the question to write a proposal for a school to purchase e.g. 5-10 Chromebooks ; and get things set up for staff to trial e.g. grab 2 high-end pixelbooks and 3-5 lower end machines to start with; do a quarterly survey; produce a report after a year.
i agree!
usually when i set up systems for education services there are a few things i disable
games (unless they have educational benefit)
setting up a web nanny (Limited content)
root access is tightly controlled
Chromebooks would certainly fit the bill better both economically and in an educational environment you as the teacher/ account administrator can monitor and control access via web service (you wouldn’t actually have to handle their equipment at all.
but i can see the op’s point too!
convincing a committee to see the need for switching can be a monumental task unless it produces immediate and positive results
yea we do have the GSuite already and so it seems like a perfect fit to move to this and yet it still takes some convincing. Surely part of the problem is the perceived status of an ipad owner (i dont know how it is still even a thing but, whatever). Great advice though, thank you! Happy New Years!
There are several reasons - but my main gripe is kids using VPNs for fortnight even DURING BREAKS breaking the rules and so forth and frankly many of our teachers dont even know what a VPN is, wouldnt have a clue. But yea, one of the problems IS kids messing around instead of doing their work. I’m curious are you a teacher too? Because immediately jumping on the ‘classroom management’ bandwagon you would know, as a teacher, that each of us has his/her own style, cultivate a particular classroom environment, deal with students in different ways, and it seems to ME as though being able to use the Google Admin features we would be able to at least limit that student ‘fuckery’ that happens in every single class in every single nation in the world regardless of teacher…i mean really man cmon…were YOU a perfect student? I sure as hell wasnt and yea, we know they’re messing around, and its normal, and I believe that this can help mitigate that. Cost is also a factor and not even TCO but initial cost. It is a private school system but with a range of incomes so $$ is always an issue. Device management is the prime concern but I personally also feel that students beyond 6th grade should be forced to use a mouse and keyboard else they risk their thumbs falling off in university trying to use ipads to write papers. Finally, I’m no hippie but I like the idea of cost savings on PAPER and the GSuite is NOT being utilized effectively because when our teachers think of iPads they think of the cartoonish apps whereas the GSuite goes underused. This would force them towards a closer-to-paperless environment. Classroom attention? Cmon man are you really asking that? Do you think i am trying to solve an attention issue by what, dulling their experience somehow? You realize that with 24 students for two hours you WILL lose some kids and need a way to get them back REGARDLESS of whether or not theyre sitting in front of paper, pad, or pixelbook, right? Anyways, whatever, have a good new years and I think I answered your questions somewhere up there haha :slight_smile:
That is exactly what I’m doing as we speak - Actually I’m starting with my personal laptop running Cloudready and I am trying to have family ship me a Pixelbook (2013) from the states so that I will have a second one. The hope is that my 5-teacher english prep team can get some sort of buy-in from the school over the next summer as a trial basis for exactly what you mean. So this is in fact working up to that point and proposal. Also things are VERY different here in Istanbul - it seems that there are a lot of backdoor deals and very little transparency in many markets in general but also this is a private school so there isnt even much transparency required. I am hoping that won’t stunt the idea but I am concerned that there may be some distributor deal or something to that effect which I don’t know about and so long story short I am doing my best to put a proposal together that they ‘can’t say no to’, if that is possible.
One additional question if you don’t mind - IF the students were to purchase their own units as may well be the case then we COULD still have those personal units under the same GAdmin console so that we COULD still limit their usage during X oclock and Y oclock as needed, correct? My thought is that we restrict them from say 8 - 4 and them free after school, weekend, holidays, etc., if that is in fact possible. In reading up on the admin console I BELIEVE that is the case, but i dont KNOW that it is. Can you please explain that or verify that it is or isn’t true? Thanks man, Happy new years!
It doesn’t matter where the device comes from, once you enroll it it’s no different than any other device.
Regarding fortnite and VPNs and such, what kind of VPN are they? How come you can’t block them with surricata and other similar stuff.
dependant on the network here.
home access could be set up dhcp which is the norm for most networking setups.
but to log into the schools computer networks a second connection needs set up with static ip address and gateway ( and no other)
this method will be able to set the policy for network access and restrict parts of it as well
for instance internet access could easily be restricted to admin levels only.
the downside of this setup would be the requirement for very stringent security protocol to prevent the inadvertent or intentional illegal access to restricted server
here is where a student and admin smart card setup comes in handy.
the access to the systems would be regulated by the individuals level of access programmed into the system by the admin.
and the student can be monitored in what they access or attempt to access, and a smart card reader at each station means no special terminals are needed for admin access as they can access from any station
if they (The students) are purchasing their own hardware it will be too hard to enforce any other policy such as to the software they are allowed to install and use. but the benefit would be lower overall cost.
equipment provided by the school however can be set up anyway the IT department and school board stipulates including removal of games or unwanted software.
software installation can be administered only by the IT staff.
barring that the measures do not work then its a matter of not allowing the devices during classes
standing on an honor policy while seemingly noble is a step in futility, and from a teachers point of view we all know that its best to get a student interested in learning But with too many students to handle its difficult at best to do that let alone properly observing which students require a little more guidance and which one need less
As for the VPN that they use, I have seen more than one, though there are so many free and cheap ones that I can’t recall which one. The school DOES block them but like the raptors in jurassic park (if you can recall) these kids jump on the electric fence that is our firewall and test for vulnerabilities constantly and my suspicion is that is part of the issue. It is possible that better administration of the firewall is needed, as a teacher I cannot say but I have brought these issues to their attention in the past and nothing has improved. That said, my thought was that if we could manage it at a device level in addition to the router level that it would add that much more protection let’s say against this kind of activity. I may have been misinformed though but what I had THOUGHT was that we could limit the apps that are used in the admin console during the school day and open them up during the rest of the day/weekends. It doesnt sound like that was correct. I realize that kids could log in to their own personal accounts and we would have to work out a way to resolve that of course. So, now I am less sure of the impact it would make in that regards. Also yes, we do have a lot of restrictions though we don’t use smartcards and so I am interested to see what that is about and will look that up. I am still going to push for these as I really believe that they should be working on laptops of some sort, and with the lower cost of chromebooks, ease of use, and fact that we already have GSuite I still think that is the way to go, but that is unfortunate that certain apps cannot be restricted. As for the student’s personal devices, if I were still in the states I would say the same thing, that we have no control over those in school…but my previous school would actually require parents to buy ipads and then lock them down and install only the apps that they chose onto them based on grades and then would open them during the summer. The student and parents had to agree to that. I always thought that was bullshit and so this sounded like a really tantalizing middle-ground.
And of course, no solution will SOLVE classroom behavior, but as teachers we are always looking at ways to improve our classroom if only incrementally and this sounded like a good one. thanks everyone for the feedback
Tech wise. Kids will always find a way to game.
Im not sure what to do about the actual curriculum. I hated school and was bored and bullied for 6 years. I would not wish high school on anyone.
Cloud based infrastructure does take the work away from schools in keeping student accounts save / secure. ChromeOS etc is a win I think.
