I have a Cisco C240 M3 with 14 x 900GB 10,000rpm hard drives and 2 Intel Optane SSDs. Currently, my setup is a bit janky because to use software RAID, I’ve created 16 different hardware RAID 0 arrays, each consisting of a single disk. After watching the latest video about reviving an old server (probably the same model as mine) Wendell said I should flash my RAID card to IT mode. Right now I have 3 RAID cards to choose from:
- The original MegaRAID 9266-8i
- Dell H200
- Dell H310.
I found an article that explains how to flash a card with the same SAS controller as the MegaRAID card and another article that explains how to flash the H310. From a first look, flashing the H310 seems to be easier but the original MegaRAID card has a supercapacitor and I don’t know if I will encounter any problems due to some strange Cisco DRM. What do you suggest? Should I flash one of those cards, or should I buy a cheap used HBA (maybe a 9210-8i)? Thanks for the advice.
