Choosing hardware for VFIO rig
Hi all, I recently got my hands on a 2080 Ti for free and I figure now is a good time to just get a whole new rig for myself. I’ve attempted GPU passthrough on Arch with my current (old) Ryzen 1700, B350 Tomahawk, and 980 Ti setup before, but I ran into issues which seemed to be undocumented, and gave up. Now however, I’m looking to try again. Is there anything I should look out for when buying a CPU and MOBO? Should I have two dedicated GPUs? I also have a 6700 xt and a 1660 on hand but preferably I would like to buy a CPU with Integrated Graphics and sell what I have. Hardware suggestions are very welcome. Right now I’m thinking a B660 with a 12600k, However I’m not sure about the ram, nor what motherboard specifically I should get. I’ve read that different motherboards even from the same manufacture have better IOMMU groupings.
It all depends on your setup of course. VFIO has a few disadvantages and very few advantages over plain Proton these days, but if you still want to do it I strongly recommend a 12- or 16 core CPU for the VFIO. You want at least 6 full cores for the guest, and on a 13600k, that could work with a 4P+4E leaving 2P+4E for the host. A 5900X with a X570 would perhaps be your best bet considering IOMMU groups.
At the same time, a 7900X or 7950X with a motherboard that has decent IOMMU groupings could help quite a lot for what you want.
