Choosing an mATX gaming case
(shameless steal from a post I made on RSI)
So, I have a TJ10S-W. I'm going for mATX, because I want to go small and portable, and it's bloody cheap for what you get. 'Nuff said. Therefore, upgrading to a 4670K, Maximus VI Gene, an RM750, and a TBD CPU cooler (it'll be cheap and interim likely). Transferring a Matrix 7970 (big triple slot card beast, will be swapped out somewhen for a dual slot [or a pair]) an SSD and HDD.
I'm looking at several mATX cases. Ideally: Not too big, good cable management, 240MM radiator support (and AIO, so Kraken X60, Corsair H100i, if possible Swifttech H220), good multi card support, capable of supporting a fully loaded mATX rig, carrying handles as a bonus. Currently budgeting for £100+, don't worry about saving me dosh. Case fans ARE an option, because they're actually rather cheap.
Xigmatek Aquila: Looks fairly good. My big concern is just cable management - I have had... deeply traumatic experiences with cables. Oh, and fan filters aren't that great with the Aquila either. This has a good chance of ending up the chosen platform, if somebody in the UK decides to stock it.
Bitfenix Prodigy M: It's basically a Prodigy rejigged internally. Same size, more gear. I'm iffy about this one at best... with my large card, it's gonna be tight, and the carrying handles don't really sway me when compared to the Aquila. But you never know - it could be great.
Corsair 350D: This is the option I'm currently working with. It's to mATX what the Prodigy is to mITX - being big. It's... yeah, big. No carrying handles either, but otherwise it wins every award.
Fractal Design ARC Mini R2: Eh... I dunno. As far as I can see... inferior 350D. Sorry Josh, please don't kill me :P
Go.
The Xigmatek aquila seems to have quite a bit of room to work in for an matx case and is relatively compact. The handles seem robust as well. Cable management shouldn't be an issue with the psu sitting beneath the motherboard and plenty of room to store cables next to the psu. The dust filters shouldn't be to hard to clean out as the entire front panel comes off ,so you could easily take a vacuum to it.
