Choosing a Monitor
So I just bought a new pc and I'm trying to choose between monitors so far I've found the Acer H236HL bid and the Asus VS247H-P, I've seen they are in the right budget range and I've seen both of them have good reviews.
If anyone knows about monitors please tell me which to choose, or another recommendation within the 150-170 dlls range please, I don't know much about monitors so I don't want to make a bad choice.
Thanks in advance.
http://www.newegg.com/Product/Product.aspx?Item=N82E16824236288
I would recommend this one.
If you can get this one
http://www.amazon.com/Dell-UltraSharp-U2312HM-IPS-Monitor/dp/B005LN1JEC/ref=sr_1_3?ie=UTF8&qid=1396566591&sr=8-3&keywords=ips+monitor
Don't know if you're still looking but I picked up the Acer H236HL bid about a week ago and overall I'm satisfied.
I did a quick review of it if you're curious
http://www.youtube.com/watch?v=BwuogPGcX5I
I use this as a second monitor, and it's great for the price!
