Do you have any tips for choosing a monitor, or is it okay to go with a cheap and nasty one?
I will need it for gaming and if possible, good value for money would be nice.
I know to look for the resolution, size and what technology it is (e.g. LED), what else do I need to look for when choosing a monitor?
T.Y. In advance :D
Supporting reviews, perhaps?
Here's what I have It's pretty cheap and has a 2ms response time so I don't notice any screen blur like my old IPS although the colours aren't as vibrant but it costs significantly less than what IPS panel monitors run for. http://www.newegg.com/Product/Product.aspx?Item=N82E16824236112
If you don't want to go with that make sure you get something with a response time of 5ms or less. I always like to go with trusted brands as quality is important and most cheap monitors have flimsy stands.
Thanks good info, anyway I don't think there will be a noticable difference between 5ms ans 2ms.
I would like 2 monitors as well, any tips?
Just grab another montior and plug it in, nothing else to it!
I bought this because I needed a monitor bad..I was tired of using my 41" TV.. I have very limited income..it doesnt have the low response time..
3btech.net/hphepaell221.html?rv=1
Get two of those
http://www.newegg.com/Product/Product.aspx?Item=N82E16824260055
Or you might want to get one of those and one with fast response time for gaming.
