Choosing a Memory Speed and Latency
Hey everyone,
I'm currently building a pc for my girlfriend as she has just graduated college and computer she has is, for lack of a better descriptor, shite. Here's the PCPartPicker page:
http://pcpartpicker.com/p/1JiGP
She'll be using this mainly for gaming for the time being. That said, her profession requires her to render/edit photos and videos quite often. She'll be building her portfolio etc for the next year at least. I will be buying Kingston HyperX Beast memory @ 16 gigs (2x8) because I've heard nothing but good things about it. However, I'm unsure of what latency/speed to buy. As I said, for now, she'll likely be just playing games and will possibly set a mild overclock on the rig.
Can you guys help me decide what latency/speed I will need to buy to help her get the best performance out of this rig? I was looking at 2133 or 2400. And be honest with me about how much the speed/latency actually helps when rendering/gaming with a dedicated graphics card is installed. Would 1600 be enough? Would it not?
Thanks so much everyone in advance for your help.
With that GPU, she won't notice a difference with 1600mhz ram.  Only get higher clocked ram if it's cheaper or are using an APU.  A nice 1600mhz kit with a CAS latency of 9 or 10 would work perfectly.
Thanks so much. I'll definitely look at getting the 1600. Just to reiterate, buying a 2133mhz set compared to a 1600mhz set of ram for ten dollars more would truly make no difference?
For gaming, anything above 1600 is pretty pointless, unless you're using an APU. Which has been said above.
For editing, a lower latency would be preferable to a higher frequency.
