Choosing a cooler for the Intel Core i5 4440
Hello, i am planning on building a computer but i need some help i don't know what cooler i should get for the Intel® Core™ i5-4440 Processor or if i should get one at all alot of people have told me that it's noisy and gives high temps is this true? or is the stock cooler fine?
If your not overclocking,don't worry about an aftermarket cooler. If you are, a Cooler Master Hyper 212 EVO will fit the bill just fine. Its only $35 aswell.
Stock cooler should be fine as you're not overclocking. However, an aftermarket cooler will perform better acoustically and thermally.
Suppose it comes down to budget but the NH-D14 or D-15 coolers from Noctua are excellent or yeah, the Hyper 212 Evo which is crazily cheap for what you're getting. I've used all of them - recommend them all. Or a H100i of course but it's most definitely overkill.
NH-D14. It's so quiuuuuurteh.
Thank you for the suggestions i am going to take a look :)
I am going to run the computer on 24/7 on many occasions so i need the temps to be good alongside it being quiet so i can sleep.
yes, nh-d14 is full of win. and when one has finished winning on one build, one may then transfer the win over to another platform for the winning to continue
Well if cool and quiet is the main goal, can't go wrong with anything made by Noctua really.
I think the NH-D14 is a bit overkill for a non overclocked chip. Pistol uses that cooler for her monster 8 core AMD, which will put out many times more heat than the i5 4440. The NH-U9B will be plenty for super low temps and low noise output, and is half the price of the NH-D14.
Yeah can't argue with that all, it is pretty beefy. No massive need to have a heatsink with 6 pipes for a 4440 unless you want it for whatever reason. The main disadvantage I see is the 92mm fan as opposed to the 140mm one on the DH14.
Just get the Hyper 212 Evo. You can't overclock that CPU anyway so it doesn't really matter.
The Evo will perform better than the stock cooler and is cheaper than the Noctua which is way overkill.
Yeah thanks for the help guys
SOLVED! :)
First of all Good day! I would just like to give thanks to the admin who posted this one I really appreciate it thank you.
Yeah right I totally agree with you! Keep up the good work and Godbless! Anyway I am here to promote followers in instagram. Guys we are real and legit.
Be with us to, attract instagram followers
