Chill Control V Mod/Hack
I have a Asetek AIO liquid cooler, and it has a tricolor LED, the software to control the color of the LED is Chill Control V. It works all the coolers Asetek makes for Corsair, Antec, AMD etc......as far as i can tell.
The Color of the LED is controlled by setting a value Between 0 and 255 for the R, B, G, LED colors . I want to write a program that makes the LED change color randomly or based on processor load / temperature but i need a way to modify the colors values
There is no API or Source Code available as far as i can tell. So I was thinking about trying to use a memory scanner to modify the memory addresses values but I am not sure how well that will work and I haven't written a program that modifies memory addresses before. so I'm looking to be told that i can't do this or any better suggestions or how to do it. I also worry that the memory addresses would change frequently
Update:
So I have run a memory scanner and the Numbers are stored as 4 byte binary. Changing the binary data changes the color of the led but the problem is that every time the program reloads it stores the values at different locations.
 I dont know where to go from here?
PS
If I'm way off base with any of this please let me know, or if its not clear what I am trying to do.
I can post screen caps of the program if it is unclear how the application works.
I would love to upload and share the finished application.
In case anyone is wondering this is my exact cooler:  http://www.asetek.com/customers/do-it-yourself/amd/amd-fx-8150.aspx
Thanks in advance
Also
Should this be in Hacking or Code
Can't really offer anything for your main question, but I think I can offer advice for your last question.
I would place this in the hacking section since you're asking about a way in which you could manipulate an already existing application for your own benefit.
Good luck!
Thanks for the response i will move it to Hacking
