I have no idea what I’m doing so I would appreciate any feedback on my parts selection for my 7980X build before I start buying items. This will be a 24/7 number crunching system, mostly running a Java software package (but also some python work). I only need basic graphics support.
Specifically, will 2 x 64 memory sticks work (or do I need to fill all the slots)?
Is my MOBO compatible with my case?
Anything I’m missing?
Thanks!
CPU: Threadripper 7980X
Case: JONSBO D31 MESH SC BLACK Micro ATX Computer Case with Sub HD-LCD Display, M-ATX/DTX/ITX Mainboard/Support RTX 4090(335-400mm) GPU 360/280AIO,Power ATX/SFX: 100mm-220mm Multiple Tool-free Design,Black
MOBO: Pro WS TRX50-SAGE WIFI MOBO
Memory: 2 x Kingston 64GB ECC Registered DDR5 5600 (PC5 44800) Server Memory Model KSM56R46BD4PMI-64HAI
Liquid Cooler: ENERMAX LIQTECH II 360, Addressable RGB All-in-one CPU Liquid Cooler, 360mm Radiator, Dual-Chamber RGB Pump, T.B. Pressure Fan Blades, AM4 / LGA 1200/1151 - AMD AM5 & Intel LGA1700 Ready
Power Supply: be quiet! Dark Power PRO 13 1600W ATX 3.0 Power Supply | 80 Plus Titanium Efficiency | PCIe 5 | Modular | Overclocking Support | 10 Year Warranty | BN501
Storage: Solidigm™ P44 Pro Series 1TB PCIe GEN 4 NVMe 4.0 x4 M.2 2280 3D NAND Internal Solid State Drive, Read/Write Speed up to 7000MB/s and 6500MB/s & 2TB
Graphics: NVIDIA GeForce RTX 3080 Founders Edition 10GB GDDR6X Graphics Card
