Check my build out
This is my build its for personal and school use. I wanna get into PC gaming and I use Photoshop, Illustrator, and I'm going to start doing some 3D Modeling.
CPU : AMD FX 8350
RAM : Corsair Vengeance 16GB @ 1600
MOBO : MSI 990FXA-GD80V2
PSU : Corsair CX600
CASE : Zalman Z11 Plus HF1(I own it already)
GPU : EVGA GTX 670 (I wanted to know if this specific card can be overclocked here's the link, http://www.newegg.com/Product/Product.aspx?Item=N82E16814130782)
SSD : Corsar Force Series 3 60GB (I already own this SSD, I just thought of including it)
HDD : WD Cavier Blue 1TB (Same thing as SSD)
Can you guys tell me if this is a good system or if it is considered a "beast". And I would have done it pcpartpicker, but everytime I try to add a part the page shows me an error.
Thanks for the help. And if any of you can recommend a better part.
thats a good pc build but maybe get a bigger ssd for it.
Should dominate anything you throw at it. My only edit would be the case but that's just personal preference.
Looks good yes, almost every gpu is oc able.
but i think there is no reason for it to do ☻
bro you actuall should ned 8gigs of ram and get 7950 or 7970,you can overclock hell out of em..
and should get barracuda,they are cheaper and have same performance
for the tasks hes using, 3D modeling photoshop illustrator, then hes better go with the Nvidia card cause for the cuda ☻
both will do fyn,,nvidia is just a bit faster in image and rendering stuff
