Check my build? (750 dollar)
Hey guys, its been a long time. Whilst I was gone, I got a job and now I have enough money to build a computer. Because I didnt want to blow my entire first paycheck, I decided to keep it under 750. This is the build..
http://pcpartpicker.com/p/1eSH6
If you guys could just check over it before I go ahead and place orders on all the parts, that would be heavenly.
Thanks in Advance
-Pat
Looks good the only thing is your mobo, make sure that its the Asus M5A97 R2.0 board. should be same price.
http://pcpartpicker.com/p/1eUQ6
i suppose you don´t need a  HDD
http://pcpartpicker.com/p/1eUL8
This is my suggestion
if youre just gaming 1333 ram is fine and also you can oc it to 1600
Thanks for the quick replies guys! Yes, I dont need a hard drive, I am just gonna get one from my older build.
