Cheat codes to utilize 2x 25 NIC without a 25gb switch?
For a 4x 10Gb SFP+ NIC its fairly easy to use the extra lanes with 10gb switches. Are there similar cheat codes for dual SFP28 cards 50Gb? The reason why I ask, is that the E810XXV-DA2 are quite cheap (150€ new), compared to 710/XXV710, but uses a bit more power.
You can breakout a 100Gb port into 4x 25Gb. Means you can get those “fairly cheap” 100Gb switches (that Mikrotik one is my crush atm) and get 4x the connections.
Or hook up a computer with a 100G NIC to 4 others, effectively making it a quad port NIC
Otherwise you can use bonding to get more bandwidth depending on the LAGG settings.
10G is to 40G what 25G is to 100G.
I have two E810’s in the 2x25G variety, am still running them with “just” SFP+ transceivers.
When transferring from my old to my new machine, I did point-to-point with a DAC and configured IPs (and priority) for that link manually.
Like @Exard3k said, 25G can be simply grouped up into 100G on the switch side.
