Cheapish monitor!
Looking for a few new monitors that i will use for gaming, preferably needs dvi and hdmi. Looking to spend about $160 a piece and going to be buying three for now.
what you you going to drive them with?
R9 280!
here is an IPS thin bezel that meets your price
AOC I2367FH - 23" AH-IPS LED-backlit LCD monitor
https://www.google.com/shopping/product/15380698948558115623?q=ips+monitor&espv=2&biw=1920&bih=955&ei=ATowVKWvMI66ogTepYKoAQ&ved=0CNwEEKYrMAE
Hey man, not sure if there's a Best Buy or something similar around you, but a lot of the time they have people return TV's and monitors so they put them out as 'open item'. May be worth a shot to hunt around at those stores a bit.
http://www.ebay.com/itm/261583628394?_trksid=p2059210.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT
I don't know much about monitors, but I bought this 2 months back and have been loving it.  23" Asus, refurbed, $125.  I can't give you anything more than that it's been good for me.
