Cheapest gpu with 10bit color output
so i wanna buy a Achieva Shimian and it says that it has a 10bit panel i dont know this is true but it would it would be nice. Anyway the title says the question. Any suggestions?
need a work station card form what I have read to get 10bit
http://pcpartpicker.com/part/ati-video-card-100505637
10bit color is really only available on workstation cards. that being said they are not meant for gaming. they can be used for gaming but you're going top be spending $$$$'s
I  know that i need a workstation card, i will only use the workstation card for outputing the image for gaming i will use a 290 or 780 not sure which one i will take
Even if you have a GPU that can output 10 bit color and your monitor has a 10 bit color display, the game itself won't output a 10 bit color signal! Every link in the chain has to be 10 bit for it to actually work, playing games with a GPU like that and on that display will simply give you oversaturated colors.
