I made one of the cheapest build I could find that included a dedicated Graphics Card. It's not good, but it's still a Graphics card.http://bennykscomps.blogspot.ca/2013/11/the-halo-rig.html
I call it the Halo rig, cause that's probably the best game you'll be able to max out with it. It's crazy that for $150 more, you could build something that can play Crysis 2.
well is still a pc but in my opinion, the best you can do is spend a little more on a better PC, because this in 3 months will be an old pc
waste of money (and a fire hazard with that diablotek psu)
THIS IS NOT SUPPOSED TO BE TAKEN SERIOUSLY!
tacopat
November 6, 2013, 12:33am
#5
But, can it run crysis? No then recycle it and start over.
Ether drop the GPU and upgrade the APU or downgrade to a CPU (APU is waisted) and get a better GPU. Otherwise your just throwing money away.
