Cheapest/Best way to build a desk?
So My license is suspended for a month. Instead of sitting on my ass eating cereal and playing payday or civ 5, I thought I'd do something productive. Like get rid of this stupid desk. Now I don't have much carpentry experience but I have a share of experience with power tools from a construction job that I held a year ago.
Now I'm not too sure about dimensions yet , about 5 or 5 1/2 feet long. I do know I want to use 2x4s. I just can't find any good builds online or guides ect. It's like no one builds a desk and shares it on the internet unless there's a computer in it.
I'm just wondering if you guys have any good links or videos, or just some insight on this
im sure instructables has something. but if i were you i'd invest in a good miter saw.
I do have a miter saw table thing. And this site is pretty awesome, thanks
Simplicity is your friend. A slab with a few legs ought to do.
You will need:
  1. Axe/Saw or pre-made lumber
  2. You will need the Saw
  3. Portable Saw Mill
  4. Planer
  5. Hand Planer
  6. Sander
  7. (Optional) hand lathe
  8. Hammer/Nails or Screws/drill
  9. Some wood glue like Elmers wood glue. (Yes, there is a difference)
  10. some rails for your drawers
  11. measuring tape.
You will have to:
NOTE: When selecting wood you generally want to avoid knots(the brown circles where the limbs grow out) when picking a piece to mill into a board. Also, avoid termites and know that many of these steps can be skipped if you're buying lumber, but you asked for something to do so here it is. ;)
  • TAKE MEASUREMENTS: How big is your desk and it's pieces!
  • Cut down some trees with your axe/saw
  • Cut them down into planks with your portable saw mill
  • Use the planer and saw to plane and cut the planks down to specifications for the desk top, drawers, and legs
  • Use your hand planer to remove any extra bark from the sides or rough spots in the wood
  • Use the sander to remove any loose splinters
  • Use the hand lathe to make some fancy desk legs or just use some milled squares from a tree(also using the hand planer and sander here)
  • build the top of your desk, drawers, etc using the hammer and nails or drill and screws. Using wood glue to fill in the cracks.
  • Sand down any extra glue once it has dried
  • Piece it all together: set up your drawer tracks, nail the top to the legs, etc.
  • Stain, lacquer, and voila... a desk!
Who said you couldn't get advice on everything at Teksyndicate.com :P
Now get to work!
(note: if you're good at wood working you can use  some wood chisels and a router to make fancy edges for your desk. These can be glued or nailed on using a router to create a slot design. You would want to use mini nails like for a doll house a ship model)
