I'm currently running low on money for now. And I need a PC. A cheap-ass PC. Maybe around $250 or something. The price are overhyped right now. Not the time. Any ideas?
Yeah, prices are really high now. I'd suggest waiting a little bit, and saving some if you could. You can't get much with $250.
http://pcpartpicker.com/p/2l6t1
I went over a bit.
If you want to be real thrifty, you can build a computer inside a cardboard box.
Just gonna wait until 2014 comes... Prices are damn high!
http://pcpartpicker.com/user/SmileAsTheyDie/saved/2DfE
1Gig of ram, with integrated graphics?! =O!!!!
lol $30 more would get him 4 gigs at 1600Mhz.http://www.newegg.com/Product/Product.aspx?Item=N82E16820231193
but that is a cheap build =o nice.
yeah i don't know about that 1GB of RAM.
Even my netbook has more than that.
With the pride point provided it seemed as performance was the last of thoughts
Performance may not be a priority, but it needs to at least perform basic functions adequately. 1GB ram won't cut it these days. For any build, no matter how cheap, 4GB should be the absolute minimum.
Here's my suggestion. Cheap and small:
http://pcpartpicker.com/p/2lekx
I agree with the 4gb of ram but as the dude has quite a tight budget,then 2gbs of ram would help his wallet.
Two gigs of ram isn't that bad when paired with win8.I'm using my old laptop with a pentium dual core with 2gb of ram running win8.Quite quick for general usage.I'm not saying its the best,but it'll tide him over until he has more funds available.
My workstation PC is a Core 2 Duo E6550 with 2GB ram running Win 7 32bit (for which 2GB is the minimum requirement). As soon as I open Outlook, AutoCAD 2014 (with 2D drawings only) and Chrome with maybe 3 tabs, the system ram is already maxed. That's only a handful of programs. Switching between programs is REALLY annoying and time-consuming. With 4GB ram, it wouldn't be a problem at all.
The OP may not be running AutoCAD, but sub that with Word/excell or some other program and a few more Chrome tabs... 2GB of ram disappears pretty quick, even just doing basic stuff.
For $15-20 more it's worth it to have a system that won't get so easily bogged down.
Not disagreeing on that.It really depends on his budget,doesn't it?
Side note,ram prices are plain ridiculous these days.
It does depend on the budget, but you have to also be reasonable and look at what your getting for your money. There are situations where it makes more sense to spend just a little more.
Ultimately it's up to the OP. Just be forewarned; 2GB ram isn't much, even for basic use.
My 2GB RAM laptop runs like potato when I use only 2 tabs. Intel Core i3 Sandy Bridge.
Adaxise, here is a tip. If you are on a budget either tight or under $500 go for AMD CPUs. They are cheap and are great for the money you pay.
Yeah, AMD's processor is pretty great at it's price. If I turn up the budget, I'd rather use AMD FX 6300 rather than Intel's i3.
Try finding used parts. You can save a lot of money but there are risk involved.
amd apu build Bang for your buck!
It is $50 over budget
But Definitely worth it.
http://pcpartpicker.com/p/2lxJW
Hey man, just save your money until you hit 500 bucks or something, you'll be much happier,.
http://pcpartpicker.com/p/2lCGZ
this has a 1tb hdd, dual core celeron, 4gb ddr3, and a geforce gt 430. this thing will even easily play fc3 @low 720p. If you want an extremely cheap pc, this is the one to buy. My build has the best gpu and cpu for the price of any of these other builds. And it seems as it would perform the best out of al the other suggestions in games.
I am really wondering where in the world do you come up with builds like these.
